08-10-2016, 05:39 PM | #1 |
Quarry Creeper Join Date: Oct 2011 Location: Westport Island
| Another 2s vs 3s vs 4s runtime question
OK. we know that a higher cell count is supposed to give a longer run time because of this: Power = Volts x Current. Ex: 11.1V x 5.0A = 55.5 Watts , 7.4V x 5.0A = 37 Watts, ect. But thats at the batteries nominal voltage and not what is actually going to the motor during "normal use". If I have a truck and do nothing but increase cell count and continue to drive around at the same ground speed lets say the motor is receiving 5 volts, does a higher cell count still make a difference? Am I comparing apples and coconuts? I normally run 3s but am dying to try 4s. Thanks! (this is something Ive struggled with for a long time now...) |
08-10-2016, 05:42 PM | #2 |
| Re: Another 2s vs 3s vs 4s runtime question
When making the switch to 3s then to 4s I noticed my run times increased significantly in every case with All other factors being equal. Another great side effect to increased voltage was cooler motor and ESC. Win win.
08-10-2016, 05:43 PM | #3 |
I just did another google search about this and found I had posted a very similar question back on 5/15!! getting old sucks... Last edited by skybolt; 08-10-2016 at 06:19 PM. |
08-11-2016, 11:39 AM | #4 |
Rock Crawler Join Date: May 2016 Location: SoWIs
Most motors will increase in efficiency if you increase voltage but maintain the same RPM/load. If not, then it's a function of how many Watt-hours are in the battery. mAh * voltage / 1000 = Wh. 4000 * 7.4 / 1000 = 29.6 Wh; 4000 * 11.1 / 1000 = 44.4 Wh. If you're a drinking man, cell count is how strong the drink is & mAh is how many drinks there are. 1 shot drank slowly will be similar to 5 "non-alcoholic" beers. |
08-11-2016, 01:55 PM | #5 |
What's a "non-alcoholic" beer??
08-11-2016, 02:16 PM | #6 |
| Re: Another 2s vs 3s vs 4s runtime question |
08-11-2016, 07:00 PM | #7 |
Bet you didn't think it was as funny as I did! Sent from my Jitterbug |
08-11-2016, 10:48 PM | #8 |
Rock Crawler Join Date: Mar 2016 Location: HB
Have another drink, throw in the 4s and hope you don't burn the biotch down.lol. Seriously though, make sure your esc can handle whatever you wanna throw @ it. Just cause you can fit it in there doesn't mean they can handle it!haha
08-12-2016, 04:15 AM | #9 |
I'm good to go, HH BRXL and CC bec, however momma told me not to drink and drive... Sent from my Jitterbug |
Another 2s vs 3s vs 4s runtime question - Similar Threads | ||||
~~runtime question~~ | 73formulabird | Newbie General | 4 | 02-07-2010 03:51 AM |
What is the runtime? | nuke24 | Duratrax Cliff Climber | 9 | 05-04-2009 06:21 PM |
No Runtime. | 350jeepcj5 | Tamiya Clod Buster | 23 | 07-01-2008 11:55 AM |
runtime question.... | weeman | Electronics | 3 | 01-08-2007 09:51 PM |
Clods With MM's...Runtime Question?? | RANOVRU | Tamiya Clod Buster | 4 | 03-21-2006 07:02 PM |
