09-05-2016, 10:21 AM | #1 |
Quarry Creeper Join Date: Mar 2015 Location: Castle Rock, Colorado
| Soldering motor leads directly on ESC |
09-05-2016, 10:36 AM | #2 |
| Re: Soldering motor leads directly on ESC
You can but why would you want to? Easy enough to just cut some male bullets down and solder across them flush to the top of the female end.
09-05-2016, 10:53 AM | #3 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
Trim the wire short and install the bullet connectors as soon as you connect them you will need to remove them 149 r/c worx team driver |
09-05-2016, 12:35 PM | #4 |
What could go wrong? Join Date: Oct 2013 Location: Southern Ontario
As the others have said, you definitely can, it's just not always the best idea. I did it on my main comp truck due to needing the wires to sit flush with the top of the ESC and not having the right connectors on hand (and instead of fixing it I've driven that truck for 6 months like that haha). Works just fine, but makes maintenance difficult and on-trail motor swaps impossible.
09-05-2016, 01:10 PM | #5 |
You can get low profile bullet connectors from TQ racing. 4mm Bullet Plugs I have used them on my rigs and they work well. |
09-05-2016, 05:10 PM | #6 | |
| Re: Soldering motor leads directly on ESC Quote:
Thanks for all the suggestions. The low profile connectors look like the answer for me. I just ordered them. Sent from my iPad using Tapatalk | |
Soldering motor leads directly on ESC - Similar Threads | ||||
Will a Yeti motor/esc bolt directly to the Wraith? | 1BAMFR | Axial Wraith | 12 | 01-21-2015 05:09 AM |
Question about Soldering ESC to Motor | DavidMaren | Electronics | 3 | 09-26-2011 07:50 PM |
Epic handwound - soldering leads | ecoli | Electronics | 5 | 05-13-2010 08:07 AM |
Soldering ESC to Motor | whipnet | Newbie General | 2 | 05-29-2008 03:19 PM |
Soldering Motor Leads | kelly_and_brian | Electronics | 11 | 03-30-2008 10:02 PM |
