01-22-2007, 10:16 AM | #1 |
Pebble Pounder Join Date: Dec 2006 Location: uk
| rooster problem
hi ive got a problem with my rooster (not super)its in my bender sw2 so its only running 1 motor and no servo(rx pack runs servo)right the problem is when i pull the throttle the light on the esc starts flashing green ive set it up again but still does it (was working then just stopped then wouldnt go again) cheers for any help nik |
01-22-2007, 10:51 AM | #2 |
Pebble Pounder Join Date: Jan 2007 Location: Superior
sounds like an set-up issue, or more acually like a signal issue, it sounds like it is not getting the signal from the radio, I could be wrong though..are you sure you set it up properly?
01-22-2007, 11:10 AM | #3 |
yep set it up right as it was working lol then it stopped gonna have anouther look as soon as ive had my dinner :-P
01-22-2007, 11:14 AM | #4 |
If the steering still works you have signal and I am not sure what it is? I would have to think it is not getting the signal to tell it what to do though?
01-22-2007, 11:35 AM | #5 |
found it im using to different brands of "deans connectors" and they dont make agood connection as if it moves just a bit it doesn't send power to the motor so all i have to do is solder on a different deans (matching pair) thanks for you help nik |
01-22-2007, 11:41 AM | #6 |
No problem, I am glad it worked out.
