11-27-2016, 05:19 PM | #1 |
Newbie Join Date: Nov 2012 Location: New Richmond
| hobbywing quicrun 1060 problem
This isn't for a crawler but close. I bought two 1060 esc's for my blizzard snow cat. I got them all hooked up they give me conformation that they are set up but I have no reverse. Now I did have to make a mix on my radio as one motor does run backwards. I have tried other radios and receivers and still no reverse, the led's light up like it's going in reverse but no power.
11-27-2016, 05:33 PM | #2 |
| Re: hobbywing quicrun 1060 problem
Do you have the jumpers installed in the ESCs? For the motor running in reverse just swap the two wires. But make sure the motor has 0 degrees of timing. |
11-27-2016, 05:47 PM | #3 |
No jumpers because I don't want break. I have put them in moved them around and still no reverse not even a bit. These are 380 motors so no advanced timing.
11-27-2016, 07:23 PM | #4 |
OK I see what you mean. I thought you wanted a brake. So yes, you should have the jumped removed for forward/instant reverse. Did you calibrate the ESCs?
11-27-2016, 08:25 PM | #5 |
I have tried multiple times with my stick radio and a pistol grip radio still no reverse.
11-28-2016, 07:11 AM | #6 |
Did you try connecting one ESC at a time and calibrating them individually?
11-28-2016, 08:51 AM | #7 |
Yes I have Sent from my SAMSUNG-SM-G920A using Tapatalk |
11-28-2016, 09:38 AM | #8 |
| Re: hobbywing quicrun 1060 problem |
11-28-2016, 09:46 AM | #9 |
Nope Sent from my SAMSUNG-SM-G920A using Tapatalk |
11-28-2016, 03:05 PM | #10 |
Then something is wrong. It would be odd for both ESC'S to be dead on arrival. Is your transmitter throttle trim set to 0? Also try reversing the throttle channel on your transmitter and recalibrate the ESC's. |
11-28-2016, 06:05 PM | #11 |
Just hooked them up one by one to a spektrum dx3s set them to that Radio and still no reverse. Guess I'm out the money and going to have to get something better. Sent from my SAMSUNG-SM-G920A using Tapatalk |
11-28-2016, 10:55 PM | #12 |
Both junk hooked up a hobby king esc for my snowblower and everything works Sent from my SAMSUNG-SM-G920A using Tapatalk |
11-29-2016, 03:16 AM | #13 |
| Re: hobbywing quicrun 1060 problem That's extremely odd. Contact HobbyWing for a warranty claim. I've had a bunch of the 1060 ESCs as well as my dad and friends and we've never blown a single one. I thought I did, but it turned out being my radio.
11-29-2016, 02:07 PM | #14 |
No warranty cause I bought them on ebay. Already going another route. Sent from my SAMSUNG-SM-G920A using Tapatalk |
11-29-2016, 02:16 PM | #15 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
I've got a Blizzard that's about to get ripped apart and rebuilt, I'm curious what you ended up doing? I'm looking at upgrading/replacing the esc's and I'd to run it off my DX6i stick radio... Have you found a good forum for these rigs? |
11-29-2016, 02:22 PM | #16 |
11-29-2016, 02:26 PM | #17 |
11-30-2016, 03:27 PM | #18 |
Pebble Pounder Join Date: Feb 2016 Location: Shelby
Are they actually hobbywing esc's or are they gool rc knock offs?
12-01-2016, 10:35 PM | #19 |
They are real ones hobbywing box and verification thingy on them.
hobbywing quicrun 1060 problem - Similar Threads | ||||
Hobbywing 1060 has no failsafe?! | QuesoDelDiablo | Electronics | 20 | 11-25-2016 12:39 PM |
Dual Hobbywing 1060 setup? | Desmo | Electronics | 0 | 06-23-2016 03:06 PM |
hobbywing 1060 with castle BEC not working | bro_die | Electronics | 2 | 01-25-2016 10:01 AM |
HobbyWing QuicRun WP-10BL60 review. | GLwagon | Electronics | 5 | 12-28-2014 09:14 PM |
