01-03-2017, 03:52 PM | #1 |
Rock Crawler Join Date: Jul 2010 Location: Great Britain
| The cold !
Is it possible the freezing tempature could be have a detrimental effect on my esc ? I'm currently running an ezrun wp sc8 on 2s my batteries are also dying pretty quickly compared to normal. Is there a bullet/water proof esc or do they all die within 6 months ? Nothing seems to be able to take a good mudding !
01-03-2017, 05:51 PM | #2 |
Quarry Creeper Join Date: Jun 2012 Location: Earth mostly
| Re: The cold !
I don't know about your esc but extreme cold will for sure make your batteries weaker Sent from my iPhone using Tapatalk |
01-03-2017, 06:07 PM | #3 |
| Re: The cold !
Colder is usually better for esc, lowers the internal resistance...should not adversely affect it. Batteries don't like to be cold (or too hot, but that shouldn't be a problem in UK), they will put out less and sometimes a charge doesn't seem to last quite as long, but I've never had this problem with lipos in cold temps. Even running at 8000 feet elevation in the snow and wind has not been a problem. How cold is cold for you? |
01-03-2017, 07:31 PM | #4 |
Rock Stacker Join Date: Nov 2013 Location: Victoria, BC Canada
| Re: The cold !
I usually lose 1/4 to 1/3 of the run time I normally would when it gets cold. Sent from my Nexus 5X using Tapatalk |
01-04-2017, 03:44 AM | #5 | |
| Re: The cold ! Quote:
01-04-2017, 05:51 AM | #6 |
| Re: The cold ! |
01-04-2017, 10:58 AM | #7 |
| Re: The cold ! |
01-04-2017, 04:35 PM | #8 |
| Re: The cold !
Correct me if I'm wrong but British and American tempature are totally different. I read something about freezing point was -20 or something ? Here 0 will freeze.
01-05-2017, 06:17 AM | #9 |
Rock Stacker Join Date: Jul 2016 Location: In the shadows
| Re: The cold !
No matter where your at on globe water always freezes at 32*F, there is a difference in how we look at those #'s, Fahrenheit vs Celsius. Not sure what the conversion is but rest assured water will freeze at 32*F, that may look different using the ole Calvin conversion, but the air/temp is the same!
01-05-2017, 06:28 AM | #10 |
| Re: The cold !
Water freezes at 0 degrees Celsius so 32F is 0C Sent from my iPhone using Tapatalk |
01-05-2017, 07:38 AM | #11 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: The cold !
Cold only seems to kill my run time, mostly due to the massive amount of snow piled in the rig. Plastic gets super brittle as well. I've been tempted to get the Bomber out, but -24F is very uncomfortable. |
01-05-2017, 10:05 AM | #12 |
| Re: The cold ! |
01-05-2017, 04:51 PM | #13 |
Rock Stacker Join Date: Nov 2016 Location: somewhere very rocky
| Re: The cold !
Does it RUIN your battery???
01-06-2017, 11:32 AM | #14 |
| Re: The cold ! |
01-06-2017, 01:15 PM | #15 | |
They don't become warm when running them. If they do... there's likely another problem. Now NiCad or NiMh yeah those can become warm during use. And should be cooled down before recharging. ------------- I've never had ambient temp issues degrading my LiPo batteries. but the colder temps could effect mechanical components... As extreme cold can cause contraction to most metal components and extreme heat can cause expansion. This effect could increase or decrease rolling resistance and create more drag or resistance for the components and battery. example extremely cold bearings and metal components can create more rolling resistance and cause things to run less efficiently, possibly even reducing run time slightly. But I'm not so sure a LiPo battery in of itself could be the fault. | |
01-06-2017, 05:41 PM | #16 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: The cold ! Yes. "The ESR of lipo packs can vary by 30 to 90% for a temperature change of 10⁰ to 30⁰C *(50⁰ to 85⁰F). (b) Winter Flying The above demonstrates why it is important to warm your LiPos before use in cold conditions.* If you launch with cold LiPos the voltage and power level is much lower, often to the point where the ESC will shut down on undervoltage.* The current through the LiPo will heat it up (and damage it!), reduce the ESR and the power will gradually rise.* This is why so many LiPos fail in cold weather.* Therefore pre-warm your LiPos in winter." http://www.smc-racing.net/index.php?...tegory&path=75 Such a bad idea. Have you ever checked a battery right after lipo cut, then wait 20 minutes and check it again? The volts go up, that's why your supposed to wait then charge. |
01-07-2017, 06:43 AM | #17 | |
Letting your pack rest before charging will increase the charge cycle lifespan of them. Sent from my iPhone using Tapatalk | |
01-07-2017, 10:35 AM | #18 |
| Re: The cold !
Will 9°f affect my lipo battery's lifespan?
01-07-2017, 10:54 AM | #19 |
Rock Crawler Join Date: Aug 2015 Location: Big Island
| Re: The cold ! Absolutely. I saw a very noticeable decrease in run time while I was in Colorado running at 15-20°F compared to the balmy 70-80° I usually run in at home. Same batteries, same rig, same type of driving, the only difference being temperature and elevation. I've run through a couple of the same packs since returning to Hawaii and there does not seem to be any permanent loss of capacity.
01-07-2017, 09:18 PM | #20 | |
The cold ! - Similar Threads | ||||
How cold is too cold to run outside? | GodSpeed999 | General Crawlers | 19 | 02-08-2015 07:02 PM |
COLD... Really Cold | PipeDreams | Tires and Wheels | 10 | 11-04-2010 03:58 PM |
When it's cold outside. | bbyrd22 | Chit Chat | 20 | 12-08-2008 06:04 PM |
Cold Chills. | JasonInAugusta | Chit Chat | 16 | 05-26-2008 08:56 PM |
