Thread: Running an LED kit on external battery
Old 01-06-2017, 01:37 PM   #1
Default Running an LED kit on external battery
29266-ASC29266-xp_led_rc_light_kit_12_leds_/
I've used many of these or similar setups where you just plug it into your receiver. But what would I need to do to run it off of a separate battery pack (besides changing the plug). Will something go up in smoke if I just plug a battery directly to the LED controller? Thanks.
ToSte is offline   Reply With Quote
Old 01-06-2017, 02:27 PM   #2
Default Re: Running an LED kit on external battery
Read the instructions, it will have most of the info you are looking for.
Operating voltage: 4.8v-6.0v
 Operating current: 100mA
You would still need to connect the signal wires if you want more functionality then just lit, IE turns and reverse.
And yes if you feed it to many volts it will go up in smoke.
Ditchrat is offline   Reply With Quote
Old 01-11-2017, 10:01 PM   #3
Looking into doing something similar. Wanting to run a whole litany of leds on a separate circuit. Looking at using a kit from My Trick RC.
SSGTOZ is offline   Reply With Quote
Old 01-12-2017, 08:31 AM   #4
PM Heyok, Tell him what you need, and "POOF" its at your door! It's magical, how he can change a little $ in to your lighting needs.
oh yeah, stock receiver power is 4.8 to 6.0 volts, anything more will leak the magic smoke out.
lzysmrf is offline   Reply With Quote
Running an LED kit on external battery - Similar Threads
External Bec/Battery pack help Axial84 Electronics 4 08-26-2013 10:59 AM
External Battery Pack kmrunner Newbie General 2 01-22-2010 08:05 PM
Does Hitec 5995/5955 servo need the external/additional battery pack? xingfuderen Electronics 2 04-11-2008 12:45 PM
2215 receiver with external battery pack Big Ahso Electronics 3 03-29-2006 08:31 PM
