09-22-2018, 06:23 PM | #741 |
| Re: What the newest cheap servo hotness?
Received the DS3225MG today - it's got a taller case than standard servos, even a touch taller than the ProModeler 470oz-in. Should be perfect for use as a 1/8th buggy servo, as I noticed my Team Associated Nomad DB8 (based on the chassis of the RC8 and SC8 racers) uses 2 spacers to elevate the RTR servo. Removing one or two of them should allow it to fit as intended. The increased size is likely because of larger components, explaining the higher torque available at a still-affordable price. Might hit upper links if mounted on-axle with flipped servo mounts...(?) BTW - I've spotted this servo over at Banggood.com for $14.99, so as long as you can fit it in your vehicle - could be quite a deal. Pics are showing size comparison next to a JX 12V BLS (which I still have never powered up) and the aforementioned ProModeler, couldn't show my Holmes Hobbies SHV-500 v1 as it is still kicking ass in my Revolver-powered Bomber... Last edited by durok; 09-22-2018 at 07:19 PM. |
09-23-2018, 06:38 PM | #742 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
| Re: What the newest cheap servo hotness? |
09-23-2018, 07:31 PM | #743 |
09-23-2018, 07:55 PM | #744 |
09-24-2018, 05:27 AM | #745 |
| Re: What the newest cheap servo hotness? thanks guys for the quick response. I understand where you're coming from. Porn Stars are either wealthy, poor, or middle class
09-24-2018, 06:55 AM | #746 |
have you guys ever heard of Kate Aubrey?
09-24-2018, 09:35 AM | #747 |
09-24-2018, 12:29 PM | #748 |
09-25-2018, 10:08 AM | #749 |
Quarry Creeper Join Date: Mar 2007 Location: winchester
been a few months now beating on the JX cls 6336 and its still working great. just fyi |
10-08-2018, 05:03 PM | #750 | |
Rock Stacker Join Date: Mar 2016 Location: Saskatchewan
| Re: What the newest cheap servo hotness? Quote:
10-08-2018, 05:21 PM | #751 | |
(and because I was sent the wrong color, I bought a new cage and body panels to paint up my way - and T-Bone bumpers, and Pro-Line F11 wheels with BadLands SC MX28 tires) | |
10-12-2018, 02:00 PM | #752 |
RCC Addict Join Date: Feb 2017 Location: Surprise
Power HD have introduced a budget-friendly HV waterproof servo LW-25MG. It makes use of a CNC-machined all-alloy case for improved durability, newly wiring outlet structure for enhanced waterproof function, having 36CM wire to compatible with Traxxas TRX-4 wiring. It is usable with 6.0V to 8.4V input, offer a torque of up to 25kg-cm at a speed of down to 0.14s. LW-25MG Specifications: Torque(6.0V): 23.0 kg-cm (319.4 oz/in) Torque(7.4V): 25.0 kg-cm (347.2 oz/in) Speed: 0.16 sec (6.0V) │ 0.14 sec (7.4V) Operating Voltage:6.0 ~ 8.4 DC Volts Weight: 72 g (2.54 oz) Bearing Type:Ball Bearing x 2 Motor Type:DC Motor Gear Type:Copper & Aluminum Operating Temperature: -20℃~60℃ Working frequence:1520μs / 333hz Size:40.7 x 20.5 x 38.6 mm ( 1.60 x 0.81 x 1.52 in) : |
10-12-2018, 02:36 PM | #753 |
That looks promising, but at $45, it's going to have to prove itself to be very durable considering other contenders in it's price range (mostly thinking of the ~$35 towerpro mg959, though it is not "waterproof")
10-12-2018, 03:06 PM | #754 |
RCC Addict Join Date: Sep 2017 Location: The OC
And what is it's draw on full stop? Pretty much anything over 20kg is gonna need an external bec. Which is fine, but you need to consider than in your setup, choice, skill set, wiring, etc. Stock esc's are pretty weak - the HW1080 is 3ah. Where is that test of all the high-power servos and what they draw on full load? |
10-13-2018, 11:22 AM | #755 | |
Quarry Creeper Join Date: Feb 2018 Location: East otis
Sent from my SAMSUNG-SM-G920A using Tapatalk | |
11-17-2018, 10:56 AM | #756 |
Check this out: https://www.banggood.com/SPT-Servo-S...r_warehouse=CN Lots of interesting specs. Runs on 6V. Has brass reinforced case. 25KG. For a great price! I was going to get some DS3225's but I might give these a try instead |
11-17-2018, 01:37 PM | #757 |
What's the protrusion coming out of the bottom of the case?
11-17-2018, 02:52 PM | #758 |
Oh wow I didn't notice that. I believe it is for if you are using a robot type setup where the servo forms a joint. Probably could be cut off easily
11-18-2018, 08:43 AM | #759 |
Newbie Join Date: Sep 2018 Location: 315
My DS3218 running off a HW1080 is quite budget friendly. Faster, smoother and quieter than the stock servo in my Redcat Everest 10, and all that I'll need.
11-18-2018, 08:49 AM | #760 | |
What the newest cheap servo hotness? - Similar Threads | ||||
Some New T1Erc Hotness! | rockpayne | Chassis and Suspension | 75 | 05-02-2014 06:23 PM |
The new bling hotness | WHITE-TRASH | Axial AX-10 Scorpion | 179 | 08-11-2013 01:34 PM |
New Hotness | 4xFord | Superclass Crawlers | 48 | 10-21-2012 08:29 PM |
The Hotness | hitman46mod | General Crawlers | 111 | 08-20-2011 01:42 PM |
