02-01-2017, 12:53 PM | #1 |
Pebble Pounder Join Date: Feb 2010 Location: USA
| 3 steering servo choices. Give a guy a hand?
Out of these 3, which would you recommend? This is going in my 1/9 Suburban trail truck, not going to try any hardcore crawling or anything. They are have fairly similar specs, but some have a bit more torque and some have more speed etc... But they are all in my desired ~$20 price range! Solar D772 Hobby King HK15298 Hobby King HK15298B Last edited by JoeThePro; 02-01-2017 at 03:07 PM. |
02-01-2017, 01:03 PM | #2 |
| Re: 3 servo choices. Give a guy a hand?
The Solar is tested and proven by many of us. Just use a BEC and it puts out a lot of power for its price.
02-01-2017, 01:12 PM | #3 |
Solar D772 best bang for the buck, imho
02-01-2017, 01:15 PM | #4 |
I joined the Band! Join Date: Jul 2011 Location: Philippines
WOW Torque (oz./in)7.4v 417 |
02-01-2017, 01:24 PM | #5 |
D772 it is, then. Thanks!
02-01-2017, 01:37 PM | #6 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
Saves me some looking
02-01-2017, 01:40 PM | #7 |
| Re: 3 servo choices. Give a guy a hand? Its strong for a low end servo but those numbers are extremely optimistic. I wouldn't be surprised if the actual torque is 100 oz less (300+ oz on 7.4V from a $20 servo is still very good though). For the OP: the Solar needs a 23T servo horn (a clamping version makes installation much easier). I don't believe that is listed in the specs anywhere. |
02-01-2017, 01:51 PM | #8 | |
| Re: 3 servo choices. Give a guy a hand? Quote:
Is something like this OK? Apex 23T clamping horn Last edited by JoeThePro; 02-01-2017 at 01:54 PM. | |
02-01-2017, 02:11 PM | #9 |
...that servo horn will work. But it would be better if it utilized two screws and was a double clamping horn like the Axial ones. ie: https://www.amazon.com/Axial-AX30834.../dp/B0076MT2SG ^ a little more coin... but could be obtained at a lower cost elsewhere. And there are lower cost chinese knockoffs to be had if wanting it even cheaper. |
02-01-2017, 02:18 PM | #10 |
Since when is solar 23 spline? All 4 of mine are 25.
02-01-2017, 02:22 PM | #11 |
Quarry Creeper Join Date: Apr 2010 Location: Baraboo
I have a pile of HK15298B & have only had one fail from me not sealing it up at the nose properly. I also have a few Power HD LW-20MG Both have worked well, but not linkage snapping power. May try this some day... Power HD B3 Brushless Digital Standard Servo - Servos - Radios & Servos | Value Hobby Last edited by GLwagon; 02-01-2017 at 02:24 PM. |
02-01-2017, 02:31 PM | #12 | |
| Re: 3 servo choices. Give a guy a hand? Did a quick search for some verification and found this from 2013: Quote:
Solar Servo from Hobby Partz? 400 oz for $23. | |
02-01-2017, 02:38 PM | #13 | |
02-01-2017, 02:41 PM | #14 |
If it slips, just glue it on, duct tape it and put a hose clamp on it... |
02-01-2017, 02:47 PM | #15 | |
02-01-2017, 03:26 PM | #16 |
| Re: 3 servo choices. Give a guy a hand? |
02-01-2017, 04:18 PM | #17 | |
Quarry Creeper Join Date: Dec 2016 Location: Cawston, British Columbia, Canada
02-01-2017, 05:35 PM | #18 |
| Re: 3 steering servo choices. Give a guy a hand?
I've had quite a few Solar D772's both 1st production and a later production. Decent low buck high torque/voltage servo... but probably under powered for heavier rigs sporting near 6" tires. 'course I now run a servo having 500 oz in in my SCX-10 and nearly 700 oz in in my 1:6 scale crawler. The D772's worked purdy good on my SCX-10 sporting 4.60" tires tho' I had problems with the later production D772's as the output would become disengaged and just spin. So tho' the motor's ran... the engagement failed to steer. Rather then hassle with returns... I just ate it and called it an experience. And now utilize more expensive/high end servos. In the later production Hobby Partz cheapened up the gears and IMO were not as quality as the 1st production run. I have 4 that the motors have burn't up... mostly my fault due to a faulty BEC / voltage setting. Then on one... the motor runs... but doesn't engage the output shaft. So I'll assume that one is from the 2nd production of 3 I purchased rnd II. Then on the final one (with the servo horn)... it runs fine... and was from the 2nd production batch. and I swapped out to the older gears instead of using the newly designed gears. Seems to be operating just fine. I also have two Axial 23 spline alloy double clamping servo horns. That I will no longer be using. One will be offered individually... The other will come with the working D772 Was going to list all of these for sale... But thought I'd mention them here before doing that. The one D772 with the servo horn attached is the good one. and was hardly used before being swapped. It was the newer production servo... But I installed the 1st production gear set. All of these have good gears in them... some just have a dead motor or the output shaft slips... 3 were from the later production and had output slippage. But the extra servos would be good for parts and gear replacements. If the OP or anyone is interested in obtaining any of these... or want them all. PM me for further discussion. as I plan to let them go for cheap. albiet... the 23T Axial alloy clamping servo horns will not come free. gear comparison of 1st production to later production... Was changed to make them less expensive in cost is my guess. ...1st prod. gear upper ...1st prod. gear lower ...1st prod gear upper Easy to see the 1st production gears had more machining done to them. And their cost was likely higher to produce. The steering slippage occurs on the gears placed individually on the towel. The primary gear and smaller gear are just compressed together... And if they're loose... the steering fails. The 1st prod. gears never slipped. only the revamped gears. Hopefully Hobby Partz has corrected the fault of their revamped production. It's been awhile so I'll assume they have. Purdy good servo otherwise... for the price anyways. Let me know if there's any interest before I post these in the classifieds. Last edited by TacoCrawler; 02-01-2017 at 05:39 PM. |
02-01-2017, 05:45 PM | #19 |
Thank you, but I already placed my order. Good info though!
02-01-2017, 06:12 PM | #20 |
Welp I don't think Hobby Partz sells replacement gears for the D772 So you may think about picking up one of my duds as back up. just in case you strip the gears. But I'll post these up in the FS classifieds in case others might have an interest. Good luck with your new purchase. |
3 steering servo choices. Give a guy a hand? - Similar Threads | ||||
Anyone wanna give me a hand | 0lllllll0 | Colorado | 2 | 12-09-2010 03:32 PM |
Give a hand on places to crawl in the east bay | ANoodle | California | 3 | 10-07-2010 01:41 PM |
can some 1 give me a hand | xr100 | Tamiya Clod Buster | 3 | 03-02-2007 10:11 PM |
new servo choices for my xf | RampageFSJ | Electronics | 4 | 05-04-2006 08:33 AM |
