03-22-2017, 05:20 AM | #1 |
Rock Crawler Join Date: Jan 2017 Location: DownUnner
| Running a sensored brushless motor unsensored with water
Odd I know but I've read that a brushless motor is ok with water and it's the sensored ones that need the be coated and waterproofed where the non sensored do not. What happens if you have a sensored motor but run it unsensored...is it then more tolerant of water like non sensored brushless? I don't want to 'try' to pull my motor apart and 'attempt ' to waterproof it when there is a decent chance it won't work or I'll kill the motor (or ESC etc). I've noticed the sensor wire has fallen out of the brushless SCX10 and it has made no difference to the low speed performance. It still crawls like a champ which got me thinking about running it unsensored as winter is approaching. |
03-22-2017, 05:23 AM | #2 |
Pebble Pounder Join Date: Dec 2012 Location: Delaware
| Re: Running a sensored brushless motor unsensored with water
The part about running sensored isn't what makes it not waterproof.. it's the pcb board inside the sensored motor that makes it not waterproof.. doesn't matter if running sensored or not.
03-22-2017, 05:38 AM | #3 |
Though if you're not using the hall sensor, doesn't the ESC just default to reading the approx position? If the sensor then gets wet does it actually matter (can it even short the motor when it's not powered)?
03-22-2017, 07:09 AM | #4 |
| Re: Running a sensored brushless motor unsensored with water |
03-22-2017, 07:44 AM | #5 | |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
| Re: Running a sensored brushless motor unsensored with water Quote:
Sensorless doesn't guess the appx position though, its actually fairly accurate of knowing where the rotor is, it just uses a different method to first detect where stuff is, which is by basically jump starting the motor to figure out where it is, hence why they have such piss poor startup... Later EddieO | |
03-22-2017, 08:01 AM | #6 | |
RCC Addict Join Date: May 2015 Location: Price Twp.
I have been fairly stubborn when it comes to brushless motors, for various reasons. However It is always in the back of my mind. Just so I don't use that statement to support my internal case against. Can the average person open a blushless to coat the lams or are brushless motors best left alone? | |
03-22-2017, 08:12 AM | #7 |
You in theory could, but it would be fairly easy to screw up....especially if you used the wrong epoxy. I would not suggest it really... Later EddieO |
03-22-2017, 09:36 AM | #8 |
RCC Addict Join Date: Jun 2016 Location: Germany
Just buy an version of motor, that it's waterproofed by manufacture. There are enough options. |
03-22-2017, 12:09 PM | #9 |
Pebble Pounder Join Date: May 2016 Location: France
On some motors you can even remove the sensor (did it on my Tenshock) and then cover/waterproof the hole were the sensor plug was
03-22-2017, 12:33 PM | #10 |
Quarry Creeper Join Date: Jun 2012 Location: Earth mostly
I've just sprayed silicone waterproofing inside and then siliconed all the seams and holes on my sensored motors. Had good luck so far. I don't really "swamp" my rigs but I've had most of them completely submerged before and I live in a rainforest area so it really wet and humid in the summer. My experience there's no such thing as waterproof just different levels of water resistance. Everything gets water in it if you use and abuse it long enough. Sent from my iPhone using Tapatalk |
Running a sensored brushless motor unsensored with water - Similar Threads | ||||
Sensored retrofit for unsensored brushless motor | ik632 | Electronics | 5 | 08-08-2012 05:26 PM |
Anyone runnung the Tekin 17.5 motor unsensored? | Anti Hero | Axial SCX-10 | 6 | 09-07-2011 09:25 PM |
running a new brushed motor in water?? | m1009cucv | Electronics | 2 | 07-06-2011 10:45 AM |
