11-02-2019, 08:40 PM | #181 |
Quarry Creeper Join Date: Oct 2019 Location: Perry
| Re: New FlySky controller? FlySky FS-GT5 6 Channel Transmitter & FS-Gi6 Receiver Set
I am loving this controller with my Sport TRX4. Did any of you figure a good way to add some lights? So far with the Hobbywing 1080 esc, I think I am just going to have to solder in a JST plug to the esc power wires. Sent from my iPhone using Tapatalk |
11-02-2019, 08:51 PM | #182 | |
RCC Addict Join Date: Jun 2017 Location: Canada
| Re: New FlySky controller? FlySky FS-GT5 6 Channel Transmitter & FS-Gi6 Receiver Set Quote:
Then a light controller to have the On/Off on the radio Sent from my Pixel 2 XL using Tapatalk | |
11-02-2019, 08:57 PM | #183 | |
Sounds good. What’s the best way to tap into the esc wired with a XT60? Do the connectors slide apart? Sent from my iPhone using Tapatalk | |
11-02-2019, 08:59 PM | #184 |
Yea you should be able to slide the black protector and access the wires. Sent from my Pixel 2 XL using Tapatalk |
11-16-2019, 12:06 AM | #185 |
Added a MyTrickRC light kit. All the lights work, but the remote wire goes to channel 3 does not toggle the lights on and off. I tried 4, and only a light blinks in the Dragon unit. It seems to be getting something but is not toggling the lights. They just stay on? Are the any settings on the GT5 to make the switch work?
11-16-2019, 04:25 AM | #186 | |
RCC Addict Join Date: Jun 2016 Location: Germany
11-16-2019, 05:43 AM | #187 | |
That’s weird. I’m trying to use channel 3 and that’s in the receiver box. The instructions for the light kit has both plugs going to the receiver box. Are you talking about the aux on the esc that you use when programming? Sent from my iPhone using Tapatalk | |
11-16-2019, 05:44 AM | #188 |
| Re: New FlySky controller? FlySky FS-GT5 6 Channel Transmitter & FS-Gi6 Receiver Set The red plug is switch control. The Black next to it is drive control. Sent from my iPhone using Tapatalk |
11-16-2019, 09:58 PM | #189 |
I guess you have to use channel 4. 3 is on and off only and there’s no customization that I could find to change how the switch works. The lights have 3 intensity settings, So for each mode low, medium, to high, that switch has to move 3x to go to the next mode. Glad I don’t have to use the manual button on the truck now lol. Sent from my iPhone using Tapatalk |
11-17-2019, 09:31 PM | #190 |
Newbie Join Date: Feb 2016 Location: fresno,ca
I am wanting to try this radio for use with a Tamiya Bruiser and the HG-P407 Brusier clone as i have had great luck with Flysky's FT3c. Can anyone tell me if the channel 4 3 position switch is adjustable with EPA? |
11-20-2019, 02:36 PM | #191 |
Newbie Join Date: Mar 2019 Location: Cape Town
so what is the verdict with using the FS-A3 receiver? still no go? i only saw this thread now... just ordered 6 FS-A3's because the manual states its compatible... |
11-20-2019, 07:46 PM | #192 |
| Re: New FlySky controller? FlySky FS-GT5 6 Channel Transmitter & FS-Gi6 Receiver Set |
11-28-2019, 08:12 AM | #193 |
Has anybody tried running 3S through this FS-B6 receiver?
11-28-2019, 08:18 AM | #194 |
| Re: New FlySky controller? FlySky FS-GT5 6 Channel Transmitter & FS-Gi6 Receiver Set 3s in the truck, yes. I have the 1080 running at 7.4 volts. Savox 1210sg running at 7.4 volts, and a Dragon Light Kit l, that used ch4 to turn to lights, bright lights low , bright lights med, bright lights high. Sent from my iPhone using Tapatalk |
11-28-2019, 12:35 PM | #195 | |
Rock Stacker Join Date: Aug 2019 Location: Arlington
Blinking light on the dragon - what style of blink? If it's a faster, repeating flash that's the low power warning. | |
11-28-2019, 12:58 PM | #196 | |
Oh nice! I will try that. I feel like I’m throwing a switch for dynamite on Channel 4 Sent from my iPhone using Tapatalk | |
11-28-2019, 03:22 PM | #197 |
The dragon looks for 0-100 as a button press, then it needs to get back to 0 signal before it’ll take another input. So one press gets from zero to 100. But then you need than 2nd click on the radio to get back to zero. What the channel 4 rocker you’d need to go through all the positions twice to equal the two channel 3 button clicks. If you set the Tx display to the channel output you can see where they are. Only 0 or 100 matter to the dragon. |
11-28-2019, 03:59 PM | #198 | |
Awesome, thanks. I’ll try that, it wouldn’t do anything for me on channel 3 when I tried it. Sent from my iPhone using Tapatal | |
11-30-2019, 08:07 AM | #199 |
Maybe channel 3 is not working on my transmitter? It doesn’t seem to do anything. Is there an adjustment or a setting not toggled on that I am missing? Sent from my iPhone using Tapatalk |
11-30-2019, 10:21 AM | #200 |
Easy to test - plug the steering into Ch 3 (or a spare servo) and toggle ch 3. That servo should go from one lock to the other with one push, and then back with a 2nd push of the button
New FlySky controller? FlySky FS-GT5 6 Channel Transmitter & FS-Gi6 Receiver Set - Similar Threads | ||||
Flysky GT3C, what's on the CD? & info for extra channel switches? | patrol_maverick | Electronics | 7 | 11-15-2013 06:10 PM |
