03-20-2018, 10:45 AM | #101 |
Rock Crawler Join Date: May 2016 Location: SoWIs
| Re: New FlySky controller? FlySky FS-GT5 6 Channel Transmitter & FS-Gi6 Receiver Set That's great to hear you're going to give it a try. Their stick radios can change between AFHDS & AFHDS 2A, so I can't see it being impossible. It would also be cool to see it become an 8ch or 10ch radio. I'm curious if the chip used is shared with the GT3, i6, i6X, or iT4 - that would really help hacking if it was the first two.
03-28-2018, 03:19 AM | #102 |
Quarry Creeper Join Date: Feb 2007 Location: Lleida
Anybody swap 5 and 6 channel rotary knobs for a 2 position switch?
03-29-2018, 06:56 AM | #103 |
Quarry Creeper Join Date: Sep 2017 Location: UK
I ordered in a cheap turnigy IA6B and it worked fine with my GT5, just no working gyro with it. Works well on the BS6 though...
03-29-2018, 12:23 PM | #104 |
The more I think about this controller the more I have a hard time choosing it over the Spektrum DX5C. Besides the lack of the sixth channel, can anybody that owns these two radios compare them?
03-30-2018, 12:28 PM | #105 | |
Quarry Creeper Join Date: Aug 2016 Location: British Columbia
| Re: New FlySky controller? FlySky FS-GT5 6 Channel Transmitter & FS-Gi6 Receiver Set Quote:
I did design an external circuit that would allow the two channels on the Spektrum to be toggled between servos and AVC, but I don't care enough for AVC to build and waterproof it, or want to spend the cash to have Al from Heyok build it for me (he is local to me) and to have to make room for it in the truck. But, if I were to try this radio out.... - aux channel 3 Rear steer - aux channel 5 2-speed shift (with a knob - but works as a visual indicator ) - aux channel 6 Mamba X Aux wire for the rock racer-crawler-toggle/drag brake adjustment. But, having just pulled the trigger on a 3D printer, it really should wait. How were you planning to use the aux channels? | |
03-30-2018, 03:50 PM | #106 | |
I don't use gyros, traction control, ABS, etc. | |
03-31-2018, 01:34 PM | #107 | |
Im planning on using channel 3 for 4WS. I then use channel 4 for 1st 2nd and DIG as its a 3 position jobbie so easy to see the gear. Then channel 5 is aux on the mamba and 6 I'm thinking about a winch at some point. | |
04-01-2018, 01:25 PM | #108 | |
Going with the stock TRX-4 radio, have you considered connecting the Mamba's Aux wire in parallel with the shift servo? Or in parallel with the diff lock servos? Or, leave the diffs locked and use that channel for the aux wire? | |
04-02-2018, 03:23 PM | #109 |
| Re: New FlySky controller? FlySky FS-GT5 6 Channel Transmitter & FS-Gi6 Receiver Set |
04-02-2018, 05:02 PM | #110 | |
I have thought about doing that with the Auxiliary wire. | |
05-22-2018, 04:20 PM | #111 |
I bought the Turnigy GT5 from HobbyKing. I also bought FS-A3 receivers and they will not bind? Any ideas why?
05-23-2018, 09:32 AM | #112 | |
https://www.rcgroups.com/forums/show...2&postcount=19 | |
05-23-2018, 10:28 AM | #113 | |
05-24-2018, 06:20 AM | #114 |
Anybody else?
05-24-2018, 09:44 AM | #115 |
Is it just that receiver?
05-24-2018, 09:58 AM | #116 |
| Re: New FlySky controller? FlySky FS-GT5 6 Channel Transmitter & FS-Gi6 Receiver Set No. I have the stock, 6-channel receiver which works fine. I also bought an FS-iA4B which works fine. Then I have four (4) FS-A3 receivers. None of the FS-A3 receivers will bind. Without an inexpensive receiver option this radio isn't a good buy. If I can't figure this out it's getting sold for a DX5C. |
05-24-2018, 10:20 AM | #117 | |
I know you don't need 6 channels, but some guy mentioned $11-14 iA6B receivers. If those work, then I'm good and still considering this system. Anything more than $15 a receiver, then I might as well stick with the GT3C. | |
05-24-2018, 10:24 AM | #118 | |
The stock, 6-channel receivers are $40! I might try the iA6B, but at this point I'm not convinced it's going to bind to this radio so I'll save my money until I know for sure. | |
05-24-2018, 01:56 PM | #119 |
05-24-2018, 02:48 PM | #120 | |
| Re: New FlySky controller? FlySky FS-GT5 6 Channel Transmitter & FS-Gi6 Receiver Set Quote: The other thing that I think would annoy me are the holes in the handle. My ring and pinky finger would be around that area. | |
New FlySky controller? FlySky FS-GT5 6 Channel Transmitter & FS-Gi6 Receiver Set - Similar Threads | ||||
Flysky GT3C, what's on the CD? & info for extra channel switches? | patrol_maverick | Electronics | 7 | 11-15-2013 06:10 PM |
