06-10-2017, 12:46 AM | #1 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
| Castle Link Graph viewer explains
Hello guys, Just testing my Puller pro 540 2200kv in my heavy Wraith with my GensAce 2200Mah Lipo pack. Dowloaded the Graph viewer and hope so someone could explain me how was my ripple voltage here. I remember my maximum ripple voltage was in 0.66V. Does it mean I am still within the safe level here? as I remember Ripple voltage peaks should always be less than 10% of the total pack voltage. Thank you [IMG][/IMG] |
06-15-2017, 03:54 AM | #2 |
| Re: Castle Link Graph viewer explains |
06-15-2017, 04:14 AM | #3 |
Pebble Pounder Join Date: Aug 2016 Location: N/A
That ripple voltage is fine especially since you're running 4S. Just wondering, does the data log show your Motor Temperature correctly? I'm running an MMX with PP 3500kv and it just shows a negative temp reading which is obviously wrong. |
06-15-2017, 04:28 AM | #4 | |
| Re: Castle Link Graph viewer explains Quote:
Not sure which one was accurate? | |
06-15-2017, 09:51 AM | #5 |
Hi Teng, Correct me if I'm wrong, but I think the readings you quoted are the ESC temps, not the Motor temps. I was actually talking about the Motor temps. Thanks! |
06-15-2017, 10:06 AM | #6 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
The esc doesn't measure motor temps, unless its hooked up. And I think only fubuta remotes are able to.
06-15-2017, 10:21 AM | #7 |
06-15-2017, 05:32 PM | #8 | |
Good morning Maverick67 Ya, it was my bad haha. No wonder the temperatures recorded was so difference. My Thermocouple average shown 55C~64C like that. But always make me wonder why the Data log shown only around 40C++ Dear 84yoda Good evevning, Thank you for your comment here. I think you were right. I remember Harley also mentioned these before....my bad again The below is my data log show the motor temperature, Max only at 1.9F ??? | |
06-17-2017, 01:21 AM | #9 | |
Good evening Maverick67, do you think this is correct temperature from the motor? Average temp 118F Which is quite near to my K-type Thermocouple. But I was shock the Max is 587.4F? Can this be true? | |
