06-09-2017, 12:12 AM | #1 |
Pebble Pounder Join Date: Aug 2016 Location: N/A
| CC MMX/MX, next firmware wishlist
I know the folks at CC try hard to improve each version of the firmware. Here's what I'd like to see in the next release: 1) Smaller increments in the BEC voltage. For example, right now you can only choose between 6v and 7.5v, with nothing in between. A choice of 6.5/7.0v etc would be nice. 2) Separate brake and reverse curves. Last edited by maverick67; 06-11-2017 at 06:31 AM. |
06-09-2017, 04:13 AM | #2 |
Rock Stacker Join Date: Mar 2015 Location: Houston
| Re: CC MMX/MX, next firmware wishlist
Most upper end transmitters have the ability to provide anti-lock braking by very quickly pulsing the brake pressure I may be brain farting badly on this, but I'm pretty surprised that I don't see some type of "traction control" programming in ESCs I know that you can tune a few different settings and achieve a more manageable/appropriate acceleration/power delivery/throttle curve to suit the surface you are running on, but it seems that it would be a relatively simple execution to put in a pulsed power delivery that would be an effective traction control without having to use a full blown AVC/gyro setup Sent from my Apple iPhone 7…which, as you know, clearly defines me as being superior to you in every way |
06-09-2017, 05:39 AM | #3 |
My castle based esc's have a torque setting along with punch and start up. Much better than a one dial traction assist. My Futaba has expo curves for throttle and brake Hang up and Drive |
06-09-2017, 07:52 AM | #4 |
Quarry Creeper Join Date: Jan 2017 Location: Olathe
Number 1 is a hardware limitation not a software one, so we can't add that functionality with a firmware update.
06-09-2017, 07:55 AM | #5 | |
| Re: CC MMX/MX, next firmware wishlist Quote:
06-09-2017, 08:25 AM | #6 |
| Re: CC MMX/MX, next firmware wishlist |
06-09-2017, 09:39 AM | #7 |
1. Why would you want or need that?
06-09-2017, 11:03 AM | #8 |
| Re: CC MMX/MX, next firmware wishlist Many servos are rated for 6.0-7.4v operation. The 7.5v option is fine for max performance and I'm not concerned about the 0.1v at all. However, there are many cases where the servo will output more than enough speed and torque at 6.0v, in which case I like to not operate at the maximum voltage to promote a longer service life and less heat. In this case, I think a 6.5v option would be a good compromise between a long service life on the one hand, and good performance on the other even when taking into account some voltage drop during operation.
06-10-2017, 02:54 PM | #9 |
Rock Crawler Join Date: Feb 2017 Location: Northern Virginia
My vote for the .5 increments in bec voltage is in with yours. I just put in a new servo rated for a max 8.4v so I just used the max setting of 8.0v. I would have Ideally set it at 7.4 or 7.5 which sounds like it could've been a very feasible option in the next update, but as @robert@castle mentioned it is a hardware setting not a software setting so out the window that goes. Setting it at 7.0 would have been to low. Last edited by MattySlimz1987; 06-10-2017 at 02:58 PM. |
06-10-2017, 08:18 PM | #10 | |
06-10-2017, 08:22 PM | #11 |
| Re: CC MMX/MX, next firmware wishlist So the only .5 increment is inside the 7v range? I'm sorry, I'm going to have to plug up my castle link tommorow and check it out. I thought it just went from 5.5, 6.0, 7.0 and 8.0v.
CC MMX/MX, next firmware wishlist - Similar Threads | ||||
Unable to locate that new MMX firmware, ver. 1.80 | Capwn | Electronics | 3 | 12-08-2016 04:51 PM |
body wishlist | obeastly | Paint and Body | 9 | 01-19-2016 06:17 PM |
Parts wishlist | sporkfu | Losi Micro-Rock Crawler | 13 | 01-16-2010 01:02 PM |
