06-20-2017, 09:47 AM | #1 |
Newbie Join Date: Jun 2017 Location: South Jordan
| Castle BEC 2.0 wire questions
The waterproof Castle BEC 2.0 has two sets of wires on the output side: +/- And +/-/signal I'm assuming that if I'm using the Holmes RX bypass y-adapter where I don't need the signal wire (signal gets passed directly from the RX), I can just use the +/- pair, or can/should I use the +/-/signal and the signal wire gets ignored? Does it make a difference? Thanks for your time. |
06-20-2017, 09:52 AM | #2 |
| Re: Castle BEC 2.0 wire questions
Bit lost, plug and play Hang up and Drive |
06-20-2017, 10:14 AM | #3 |
| Re: Castle BEC 2.0 wire questions |
06-20-2017, 10:26 AM | #4 |
Gotcha! Iirc, the triple is servo, dual is acc, lights or winch Hang up and Drive |
06-20-2017, 12:10 PM | #5 |
Quarry Creeper Join Date: Jan 2017 Location: Olathe
The two wires are hooked together internally. There is just two of them because if you are using near the capacity of the BEC you'll melt the connector. If you are using the bypass harness you can hook the 3 wire one up to the servo and then have the 2 wire one to be hooked up to some LED's or a winch. The only reason one of them has the 3 wires is to be able to communicate with Castle Link, for power they are identical and you can hook them up where ever you need power.
06-20-2017, 04:17 PM | #6 |
Thanks everyone.
06-20-2017, 04:26 PM | #7 | |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: Castle BEC 2.0 wire questions Quote:
Removing 75% from the box to run off the second output is perfect. The package says both outputs must be connected to the receiver. | |
04-02-2018, 01:23 AM | #8 |
Quarry Creeper Join Date: Mar 2018 Location: Park Hills
glad I found this thread because I couldn't figure out why it comes with two outputs.
05-18-2018, 03:04 PM | #9 |
Newbie Join Date: Apr 2009 Location: belle vernon
Thanx ! This is the exact question I had. I just put some heat shrink around the second power lead coming from the bec.
01-20-2019, 06:58 PM | #10 |
Newbie Join Date: Jan 2019 Location: salem
Thanx, I've been scratching my head for two days. CC should have that info on there web site.
02-04-2019, 03:25 PM | #11 |
Quarry Creeper Join Date: Feb 2009 Location: Glendale Az
So I can power 2 servos on a super with only one BEC 2.0?
Castle BEC 2.0 wire questions - Similar Threads | ||||
Castle BEC 2.0 wire questions | Hazenhart | Newbie General | 0 | 06-17-2017 02:22 PM |
how do I wire/solder a Castle 10A BEC to an AE-2 esc, to run 3S LiPo? | ussprinceton2004 | Electronics | 9 | 02-09-2012 02:18 AM |
how to wire a single fxr punk dig and castle bec | krazycrawler888 | Electronics | 5 | 09-19-2011 10:33 PM |
castle bec? what does the signal wire do? | driftin90 | Electronics | 2 | 07-19-2009 05:16 PM |
quark 33 and castle BEC. remove esc power wire? | dieselfuel | Electronics | 2 | 03-21-2008 12:12 AM |
