07-20-2017, 01:48 PM | #1 |
Rock Stacker Join Date: Feb 2017 Location: United States
| Puller Pro BL 540 Standard vs Puller Pro BL 540 Stubby
Hi guys, What are the pros and cons of these two motors? |
07-20-2017, 02:24 PM | #2 |
Quarry Creeper Join Date: Feb 2011 Location: Nevada
| Re: Puller Pro BL 540 Standard vs Puller Pro BL 540 Stubby
I have ran the stubby in an SCX10 II and a Standard and XL in a Bomber. The stubby is the best brushless motor I have had in a SCX10. The Standard is my favorite in the Bomber. I now have the XL in a Yeti trophy Truck. In my opinion, The Stubby is great for smaller rigs (1.9). The Standard is good all around. The XL is a power beast but lacks at the super slow crawling. FWIW, I run all my Puller Pros on 3s. The Stubby is 2200 KV. The Standard and XL are around 3500 KV. Awesome motors! |
07-20-2017, 02:32 PM | #3 |
RCC Addict Join Date: Aug 2008 Location: Paulina
Pros- both are great motors. cons- Really depends on your application as to which is suggested. |
07-20-2017, 02:34 PM | #4 |
Newbie Join Date: Jul 2017 Location: Northern
| Re: Puller Pro BL 540 Standard vs Puller Pro BL 540 Stubby |
07-20-2017, 02:48 PM | #5 | |
| Re: Puller Pro BL 540 Standard vs Puller Pro BL 540 Stubby Quote:
07-20-2017, 02:56 PM | #6 | |
I beat the snot out of this rig at the Axialfest Ultra 5k last week. No troubles. | |
07-20-2017, 03:05 PM | #7 |
| Re: Puller Pro BL 540 Standard vs Puller Pro BL 540 Stubby Thanks, I am considering putting one in my bomber. Ether that or save $60 and install a mamba x castle sensord combo
07-20-2017, 03:38 PM | #8 |
Another Axialfest plug, my son took 1st place in the 11-15 year-old Rock Race event with his Bomber. Puller Pro Std 3500 KV, Mamba Monster X, 3s.
07-20-2017, 04:29 PM | #9 |
Pebble Pounder Join Date: Sep 2009 Location: tulsa oklahoma
What are the trade offs of having a stubby? Shorter, smaller, lighter? Does that mean it has less power too? Trying to learn something. What I mean is, say you had a 2200 kv stubby in a standard scx10. What kind of difference would you see, if you swapped it out with a standard 2200 kv? Last edited by slam49; 07-20-2017 at 04:31 PM. |
07-20-2017, 06:55 PM | #10 | |
I once read that the stubby is basically the same output as a Tekin Pro4 and the Standard is similar to a Pro4HD. Difference is Holmes are tuned for better resolution at lower RPMs. I feel that is pretty accurate. | |
07-20-2017, 07:05 PM | #11 |
07-21-2017, 10:50 AM | #12 |
Stubby ..... should be perfect size/weight Hang up and Drive |
07-27-2017, 08:02 AM | #13 | |
Quarry Creeper Join Date: May 2012 Location: Italy
I have both, Stubby and Standard, both 2700kv since I wanted to stay in the mid range speed, though you may like the 2200 stubby for your purpose.. They are just great motors...! | |
07-27-2017, 08:12 AM | #14 |
Rock Crawler Join Date: Mar 2016 Location: HB
Is there a difference in operating temperature between the two? Will a stubby heat up faster because of the shorter can?
07-27-2017, 08:27 AM | #15 |
07-27-2017, 08:43 AM | #16 |
Thanks slimfire. I'll have to give the stubby a try. Been using the standards in most rigs but my new build might benefit from a bit less weight.
07-27-2017, 09:06 AM | #17 |
Get the Holmes motor not the Castle motor. I have no experience with the new Castle motors, but I do have the Holmes and it's awesome. It's my second favorite behind the Tekin ROC412. For the Bomber I would suggest the standard NOT the stubby. I just see no reason to get the stubby when you have plenty of room for the standard in the Bomber. It would be interesting to see what JRH would say in this case. Get the Mamba X ESC. The auxiliary wire was made for vehicles like the Bomber! Edit: Here's a post from JRH from a similar thread. Last edited by JatoTheRipper; 07-27-2017 at 09:10 AM. |
07-27-2017, 05:46 PM | #18 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
Love my Puller Pro 540 2200kv always. However, if I have smaller and lighter rig like SCX10, I will go for Stubby |
07-31-2017, 08:21 PM | #19 |
Pebble Pounder Join Date: Jun 2017 Location: United States
So what does the number for the KV represent? I was thinking about this one (thanks mikemcE) but not sure what the number means. I will be running a wraith at about 10lbs and a Mamba Max Pro. I want to crawl but haul some ass occasionally. Suggestions?
07-31-2017, 09:48 PM | #20 |
| Re: Puller Pro BL 540 Standard vs Puller Pro BL 540 Stubby then get the puller pro 3500kv, i have it and it is perfect for what you want to do....
Puller Pro BL 540 Standard vs Puller Pro BL 540 Stubby - Similar Threads | ||||
Motor Selection Help Needed - HH Puller Pro 540 vs HH Puller Pro 540XL | WesTX | Electronics | 18 | 09-14-2016 09:16 PM |
Holmes Puller Pro 540 standard vs XL | Jus | Electronics | 23 | 01-31-2016 06:28 AM |
