07-31-2017, 05:27 PM | #1 |
Quarry Creeper Join Date: Apr 2017 Location: Melbourne Australia
| Whats more important - ESC or Motor?
Hi all, Bout to buy a Twin Hammers clone for a custom project and I am trying to figure out a decent sensored waterproof brushless setup which doesnt cost 3x the amount of the rig! I want the ability to still crawl as well as possible but then have a roughly 30mph top speed. The TH 2 speed trans will help with this. No holds barred choice would be the new CC Mamba X with 2850kv slate motor. But thats tipping the scale at over $300aud landed. So i have been deep down the rabbit hole comparing all of the other ESC options out there from the likes of SkyRC, Hobbyking, Yeah Racing, Hobbystar. I have found this ESC - Hobbyking 70a Sensored Waterproof And then was thinking of pairing it with a - CC 2850kv Slate motor which are in the scheme of things, reasonably priced at $100aud. But there are cheaper options for a sensored brushless motor. So my question is, am I better off spending more on the esc than the motor? I would like to get out of it for less than $150. I also know that a sensored motor needs to be made waterproof...and even then its still not going to love water. Cheers |
07-31-2017, 06:01 PM | #2 |
| Re: Whats more important - ESC or Motor?
Or do i gear down a few teeth and let the low gear in the transmission do the work and go with a waterproof sensorless setup iike this? HobbyStar 1/10 Waterproof Combo, 60A Brushless ESC, 4-Pole 3100KV Motor RC Car | eBay |
08-01-2017, 12:25 AM | #3 |
Newbie Join Date: Apr 2017 Location: NY
You mean ESCs+Motors within $150?
08-01-2017, 12:38 AM | #4 |
yes motor and esc for $150.
08-09-2017, 12:01 AM | #5 |
Rock Crawler Join Date: May 2016 Location: SoWIs
The ESC is the most important thing if you aren't doing dead-serious crawling. Even cheap motors will give you tons of power, they'll just be a little less efficient. Cheap ESC's will go up in smoke pretty quick when bashing hard, and even good ESC's can give up with enough bashing. I like to just go complete overkill with the ESC, so you only buy once. That said there are a couple 120-150A esc's out there that work well (HobbyWing/Trackstar/SkyRC/etc). Most are in the $65-110 range, with the upper end having sensored capabilities. They're designed for 4074 motors, so they simply laugh at 3650 motors like the 1406. You can do 2-4S if you want. The 70A model may be enough, but if not then you're out $32+ and need to spend more anyways. |
08-09-2017, 12:18 AM | #6 | |
| Re: Whats more important - ESC or Motor? Quote:
Will thrash the trackstar 13.5t the used TH I bought comes with til it dies and then grab the Slate motor. Sent from my Pixel using Tapatalk | |
Whats more important - ESC or Motor? - Similar Threads | ||||
Whats more important for performance? Esc or Motor? | littlebuddha | Electronics | 3 | 06-20-2016 08:50 PM |
whats the best motor and esc to use in the scx10 | Icer.One | Axial SCX-10 | 28 | 11-11-2012 04:20 PM |
whats the best esc/motor combo for the lnc? | newblnc | Team Losi Comp Crawler | 1 | 04-11-2011 11:35 PM |
Whats a good motor for STOCK ESC? | it8ezbngrn | Losi Mini-Rock Crawler | 21 | 04-05-2009 11:35 AM |
