08-13-2017, 11:12 AM | #41 |
| Re: Castle Link
And now we have a 20a wp bec, sensored motors and the aux wire on the "X" versions, Positive thinkers get ahead, Robert is also liking that IIRC. Hang up and Drive |
08-13-2017, 11:48 AM | #42 |
Rock Crawler Join Date: Feb 2017 Location: Northern Virginia
| Re: Castle Link Wow 7 years!? It must be the demand or somthing similar, afterall it must take a lot of time and money to develop an app like this with what seems like much complexity.
08-13-2017, 11:58 AM | #43 |
| Re: Castle Link
Here's 3 Castle Link items - The Duo is for Aux Channel users:
08-13-2017, 12:57 PM | #44 |
| Re: Castle Link |
08-13-2017, 01:45 PM | #45 | |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: Castle Link Quote:
Look at tekin, they got bluetooth. They listened. | |
08-13-2017, 02:11 PM | #46 | ||
The Duo is seemingly a matter of convenience for Aux-channel Castle ESCs... Edit from Castle page: "Keep your wires neat! Experienced modelers go to great pains to tie down their servo and throttle leads, and some find unplugging a Castle controller from the receiver disrupts all their work. Many have asked for something like a Y connector that gives an open lead for easy Castle linking, but a traditional Y harness doesn't work when the other branch of the Y is connected to a receiver - the signal line must be disconnected from the receiver. Quick Connect Duo detects the presence of a Castle Link adapter on the free lead and switches the controller's signal line from the receiver to the Castle Link. Quick Connect Duo supports all Castle Link capable ESCs but is designed specifically for use with Castle ESCs featuring AUX wire technology. The Quick Connect Duo is recommend for the following ESCs: Surface - Sidewinder 8th, Mamba Monster X, Mamba X, Mamba Micro X. Air - Talon, Talon HV, Phoenix Edge, Phoenix Edge HV." Last edited by durok; 08-13-2017 at 02:14 PM. | ||
08-14-2017, 09:06 AM | #47 | |
Quarry Creeper Join Date: Jan 2017 Location: Olathe
The card works just like a castle link. USB cord from the card goes to a port on your computer and then you hook the 3 wire rx wire from the esc up to the header on the card. You can not use the white AUX wire to castle link. The Quickconnect that was talked about here is a tiny little module that sits inline of the rx wire and gives you a wire to hang out of your car so that you don't have to unplug your ESC from the receiver. Edit: Tiny bit of clarification: The field link card isn't 100% compatible with the quickconnect. It will work when hooked up to a computer's usb, but will not work as a standalone card. I need to run a test on it sometime because I have a theory that it will work if you power the card with a usb battery(cell phone external battery pack) before plugging it into the quick connect. Last edited by robert@castle; 08-14-2017 at 09:33 AM. | |
08-14-2017, 09:16 AM | #48 | |
I think I partially misspoke. We recommend the Duo for all X series controllers because it makes the wiring of the AUX wire easier. It is possible to wire up a normal quickconnect to most x series controllers, but not as easy to convey to the end users, so we normally just tell people to get the Duo to simplify the process. | |
08-14-2017, 11:46 AM | #49 | |
08-14-2017, 12:14 PM | #50 | |
Rock Crawler Join Date: Nov 2014 Location: Dells
08-14-2017, 02:49 PM | #51 | |
The Quickconnect Duo only disconnects rx wire and the red wire from the wire going to the receiver. The rx signal wire is disconnected to prevent interference in the castle link communication. The red wire is disconnected to keep the radio and servos from powering up off the castle link. I just looked at the schematic of the Duo and it leaves the AUX wire hooked up to the receiver at all times. The Duo is only truly required if the AUX wire has an extra set of BEC and ground wires attached to it like it is on the Mamba XLX. We recommend it for all AUX wire products because it is hard to explain when people need it and because it simplifies the wiring slightly to have all wires from the ESC going to the quick connect. | |
08-14-2017, 04:22 PM | #52 | |
08-16-2017, 12:33 PM | #53 |
Newbie Join Date: Apr 2008 Location: Overland Park
| Re: Castle Link
To add a bit more to the discussion of the Quick Connect versus Quick Connect duo and when to use each one. The only surface ESC that absolutely needs the Duo is the Mamba XL X (1/5th). But Castle Tech Support has been recommending the duo for the Mamba X and Monster; but not because of the auxiliary wire but due to current ratings of the on-board BEC versus the original Quick Connect. When the regular Quick Connect was released we didn't have high amperage on-board BECs that the Mamba X and Monster X utilize. The BEC's on the Mamba X and Monster X are rated for more current than the Quick Connect. Running a single servo should be fine; but when you start adding in a winch, diff/shift servos you may pull too much current through the Quick Connect. This can potentially damage the Quick Connect or cause voltage drops to the receiver and leads to brown outs/glitching. The Quick Connect Duo's amperage rating was increased to match the upgraded BEC capabilities of the X-series. TL;DR: The Quick Connect should work with most applications; but the Duo is preferred when using more than a single servo due to the current draw and current capabilities of the Quick Connect. Hope this helps clear things up a bit! Thomas Porfert Tech Support Castle Creations |
08-16-2017, 01:44 PM | #54 |
| Re: Castle Link
Good call Thomas, I was only thinking about Castle Linking though the Duo and forgot about the BEC current handing of it.
09-20-2017, 03:33 PM | #55 | |
Rock Crawler Join Date: Jun 2017 Location: Land of burning couches
MattySlimz did provide me with a castle link code (stand up of the man to do, need more of this kind of thing in the community) it worked flawlessly and I had my very own castle link in about 9 days or so. I will say for anyone who utilizes a code, it does not come with attachment cable for a computer so you'll need one. I happened to have an old charging cable from Playstation controllers that works like a charm. Thanks again MattySlimz, stand up guy!! | |
