08-15-2017, 05:50 AM | #1 |
Newbie Join Date: Aug 2017 Location: Utah
| Banana y to servo
Im looking for a banana battery plug with a servo power coming off. For direct servo to battery power on a everest 10 for 4ws
08-15-2017, 11:37 AM | #2 |
| Re: Banana y to servo
Pull out the servo power wires from the connecter, cut off the things, and solder the wires to the ESC battery plug.
08-15-2017, 12:14 PM | #3 |
Quarry Creeper Join Date: Oct 2012 Location: Oregon
You also need to Y into the black ground wire... Here is a quick sketch. |
08-15-2017, 12:34 PM | #4 |
| Re: Banana y to servo |
08-15-2017, 01:01 PM | #5 |
Without the ground also connected the receiver and BEC is also part of the full battery voltage path and has to deal with the amps the servo is drawing, which could be fine depending on how the negative is constructed in them. The T'd in negative will just make sure they are not being required to carry the full load on a stalled servo.
Banana y to servo - Similar Threads | ||||
Banana Plugs | AG74683 | Electronics | 11 | 09-04-2011 10:44 AM |
Top Banana | quattros | Tamiya TLT Crawlers | 13 | 05-15-2008 10:42 AM |
I'm A Banana | joehein | Chit Chat | 3 | 01-29-2007 06:34 PM |
banana plugs | 90DEGREES | Electronics | 1 | 10-15-2004 08:17 PM |
