08-22-2017, 04:39 PM | #1 |
Rock Stacker Join Date: Jan 2014 Location: Rockford MI
| Kyosho Blizzard Electronics upgrade
Hi everyone, this Christmas I got a Kyosho blizzard FR, it wasn't long before I ended up burning up a drive motor. After that I upgraded both drive motors to dromida speed secret 22t brushed motors still running on the stock esc's, worked well for a good while and then the left esc failed. Now I am looking to upgrade to a sabertooth 2x12a esc and possibly new motors. I've been researching and I thing the sabertooth would be a good option but I'm also open to a dual esc setup, I don't think I want to go brushless though. I have a few questions regarding the sabertooth, would I still be able to run my dromida 22t motors or would I need to upgrade right away? Also I'm looking for torque rather than speed, I thought it was plenty quick enough out of the box and I'm running metal tracks so that could add a bit of stress also. I saw a few videos where the 370 size motors couldn't handle the sabertooth esc but 380s worked fine. Any help would be appreciated thanks! Sent from my iPhone using Tapatalk |
08-22-2017, 07:42 PM | #2 |
RCC Addict Join Date: Aug 2014 Location: Virginia, Near DC, USA
| Re: Kyosho Blizzard Electronics upgrade
Well...I was all set to link you to my Kyosho Blizzard build thread, but I can't seem to find it on any of the forums I post on. I must've forgotten to write one. I installed a couple cheap 4000KV 370-size brushless motors and a couple cheap 1/18-scale brushless ESCs. Works great. |
08-23-2017, 07:15 PM | #3 | |
| Re: Kyosho Blizzard Electronics upgrade Quote:
Thanks for the help, do you thing you have better torque or pushing power over factory? Sent from my iPad using Tapatalk | |
08-24-2017, 08:32 AM | #4 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
I'm running the Sabretooth on the stock motors and I think it's a great balance of speed and torque. I don't know what the stock motors are though (I just haven't put that much time into the Blizzard yet so I'm still figuring it out). I've never really tested the limits of how much torque it has, The only times I've used the blade was in snow so I ran out of traction before I ran out of torque. Not sure about your question on 22t motors, that seems like a detail you should be able to get from the folks that make the Sabretooth? |
08-26-2017, 10:13 PM | #5 | |
Extra torque won't do much good without the rubber-and-metal caterpillar treads, though. The stock plastic treads don't provide much grip, and they get stiff in snow. | |
02-21-2020, 01:47 PM | #6 |
Newbie Join Date: Feb 2020 Location: Schaumburg
Does anyone know of a way I can eliminate the stock radio so I can use a pistol grip transmitter? A sabre tooth esc won't work because I have dual brushless motors and escs installed. That esc is for brushed motors I believe. I've spoken to 2 local hobby and researched it on the internet but can't get a detailed answer. Thanks sooo much for any insight. |
02-21-2020, 01:57 PM | #7 | |
Quarry Creeper Join Date: Jan 2017 Location: Olathe
Here is an example of one: https://www.mtroniks.net/prod/RC-Acc.../Tankmixer.htm | |
02-21-2020, 09:08 PM | #8 |
Thanks so much. I will check that out.
02-21-2020, 09:10 PM | #9 |
I assume that's differant from an airplane v-tail mixer ?
02-21-2020, 09:17 PM | #10 |
Would you happen to know what is that switch on the stock transmitter next to the reverse adjustments that's labeled " v-mix?" There is NO mention of its function in the manual. It is on the very front of the transmitter.
02-23-2020, 03:49 PM | #11 |
Any of you Blizzard owners. Do you know what that "v-mix" switch on your stock transmitter does ?
02-24-2020, 04:20 AM | #12 |
Quarry Creeper Join Date: Jun 2013 Location: Twin Lake
The v mix on the controller allows you to have forward/ reverse on 1 stick and turning on another. That's how I have mine setup throttle on the left steering on the right. For motors I went with redcat 380 motors and 2 hobbywing 1080 esc. The blizzard should have come with 380 motors in the first place in my opinion. The motors run cool and longer then the stock 370 ones that it comes with. The redcat motors have 0 timing so they can run either direction at the same rpm. I looked at the saber tooth but decided if decided I didn't care for running the blizzard anymore I would at least have 2 hobbywing 1080. |
