09-03-2017, 02:43 PM | #1 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
| Castle BEC minimum voltage drop?
I'm looking at a Castle BEC for my bomber. I would like to set it at 8.4v for when I run on 3s. If I run 2S, what can the BEC put out? For simplicity I want to solder the BEC power to the esc battery feed, but if my voltage on 2s is going to be much below 7.4v, I'll build a harness that can pull servo power from the 2s balance plug instead.
09-03-2017, 02:57 PM | #2 |
| Re: Castle BEC minimum voltage drop?
It cannot increase voltage, it regulates it Hang up and Drive |
09-03-2017, 02:59 PM | #3 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Doesn't matter if you hook it up to esc plug or balance plug, if your running 2s its going to put out whatever the battery voltage is since you'll have it set to 8.4v. Its easier to hook it up to esc plug so you can run 2s or 3s without having to have 2 different harness for 2s or 3s off the balance port.
09-03-2017, 03:29 PM | #4 |
| Re: Castle BEC minimum voltage drop? |
09-03-2017, 03:32 PM | #5 | |
| Re: Castle BEC minimum voltage drop? Quote:
Castle's literature says that it can pass battery voltage with almost no drop, but I'm skeptical because most regulators max out at 1-1.5v below battery voltage. | |
09-03-2017, 03:35 PM | #6 |
You need to ask Thomas from Castle, not us users. Hang up and Drive |
09-03-2017, 04:14 PM | #7 |
You might have 0.1v drop. If you dont believe castle who made it, you can test this yourself if you have a multimeter. Why would they make a bec that would drop that much, lol.
09-03-2017, 04:41 PM | #8 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
Because sometimes technology dictates that much drop... not saying that's the case here. Can't someone just measure this? Sometimes I'm stumped by how generally low-tech folks in the hobby can be. |
09-03-2017, 04:50 PM | #9 |
I just tested this for you, 3s battery with bec hooked up to balance port, bec is set to 7.4v. Output was 7.39v.
09-03-2017, 05:43 PM | #10 | |
Just to provide a better explanation, normal voltage regulators that bleed off excess voltage can only output a maximum voltage ov about 1v to 1.5v below the input voltage. In other words, if you have a BEC set for 8.4v, in 3S it will output 8.4v, but that same BEC might only output 6.9v when powered by 2s. Because I don't have any experience with switching-style regulators like the Castle BEC, I'm asking the question before I piss away $20 for a BEC and another $20 for the Castle Link, only to find out it won't do what I want. | |
09-03-2017, 06:07 PM | #11 |
Quarry Creeper Join Date: Apr 2017 Location: Melbourne Australia
A BEC doesn't 'create' voltage. To get 8.4v from a 2s you would need a step up converter.
09-03-2017, 06:18 PM | #12 |
| Re: Castle BEC minimum voltage drop? I know a BEC can't step up the voltage. That's not what I'm asking. A fully charged 2s puts out 8.4. Im just trying to find out how much drop I'll get through the BEC!
09-03-2017, 06:20 PM | #13 |
09-03-2017, 06:35 PM | #14 |
Why don't you understand that its going to put out whatever the battery voltage is. I just did another test for you, using a 2s battery. Same bec set to 7.4v, my 2s battery is at 7.34v and bec output was 7.34v. So like castle and I said, no voltage drop or if anything 0.01v drop.
09-03-2017, 07:21 PM | #15 | |
Thanks for comparing the 2s output voltage to the input. That's what I needed. Last edited by Jim85IROC; 09-03-2017 at 07:25 PM. | |
09-03-2017, 07:22 PM | #16 |
09-03-2017, 11:39 PM | #17 |
| Re: Castle BEC minimum voltage drop? Testing done. One charged battery testing at 8.3v and one semi flat testing at 7.5v. Bec set at 8.4v So the BEC will pass through what ever voltage the battery can give up to the voltage limit you set on the BEC. So yeah a 2s will start out at 8.xx but as you run it down you will finish your run only giving servo 7.4v Sent from my Pixel using Tapatalk |
09-03-2017, 11:42 PM | #18 |
Also, I think the large voltage drops are because: 1. The 2.0 Bec has two outputs which you encouraged to run in tandem to your receiver. 2. I was trying to test across the exposed parts of the pins on the plug whilst trying to take a photo = not great connection. 3. Voltmeter is pretty shitty. Good one was flat. Sent from my Pixel using Tapatalk |
09-04-2017, 07:58 AM | #19 |
Thanks! It's impressive that the switching regulator can pass the input oower through so efficiently. Thanks for the confirmation!
09-04-2017, 09:14 AM | #20 |
RCC Addict Join Date: Aug 2013 Location: Missoula
Rob did say the MambaX internal bec will drop a half volt. I only run 3s on my Bomber, never payed much attention to it. |
Castle BEC minimum voltage drop? - Similar Threads | ||||
Castle Creations BEC 2.0 15A Waterproof Voltage Regulator | RPP Hobby | RPP Hobby | 0 | 11-26-2016 11:16 AM |
Castle Creations BEC 2.0 14A Voltage Regulator | RPP Hobby | RPP Hobby | 0 | 11-26-2016 11:11 AM |
Castle BEC voltage increase? | hanstone | Electronics | 4 | 09-28-2012 03:19 AM |
Castle BEC voltage | natskiboy | Electronics | 19 | 05-19-2012 08:10 AM |
How to change output voltage of Castle BEC??? | RedBetta | Electronics | 6 | 12-03-2007 11:10 AM |
