01-26-2019, 04:35 PM | #1041 |
| Re: Have tech questions? Will answer.
Yes, you can limit max power in castle link. About 75% would be the speed you want.
01-26-2019, 04:54 PM | #1042 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
Ok good to know, thank you.
02-04-2019, 02:29 PM | #1043 |
Rock Crawler Join Date: Dec 2005 Location: Marietta
I picked up the non waterproof TrailMaster BLE Pro. How hard would it be to waterproof?
02-05-2019, 12:32 AM | #1044 |
Quarry Creeper Join Date: Apr 2018 Location: US
| Re: Have tech questions? Will answer. |
02-05-2019, 02:08 PM | #1045 |
Hey, got my Gen 8 scout and am wanting to get a better motor than the stock one. I think the stock one is 17t and was trying to decide between brushless and brushed. I was thinking a 21t torque master expert or pro would give me more power and torque than the original pus slow it down just a tad the other option was maybe a BLE and a 2700-3300kv trailmaster pro or a 2700-3500kv puller pro...any suggestions? |
02-05-2019, 02:15 PM | #1046 |
Brushed I would select a 550 21t. Brushless, 2700kv would be near stock speed I estimate. I almost always use a 3500 Puller if not a 1800 revolver for my personal single speed builds.
02-05-2019, 03:47 PM | #1047 |
02-06-2019, 08:42 AM | #1048 | |
| Re: Have tech questions? Will answer. Quote:
Sent from my Pixel 2 using Tapatalk | |
02-06-2019, 08:56 AM | #1049 |
On the topic of Gen 8 with a Trailmaster and BLE, I installed one in mine. (the 2700kv one that was available on special) Trying to go forward, I have to go 1/2-2/3 throttle pull before it will move forward. But I barely touch it to go backwards, and it jumps backwards way faster. I've tried to recalibrate, tried adjusting in the Castle Link to give it a curve, nothing seems to work. Any thoughts? I'm still using the stock radio, wondering if that's part of my issue? Sent from my Pixel 2 using Tapatalk |
02-06-2019, 09:55 AM | #1050 |
Sounds like you have reverse and forward backwards. When accelerating the led on the esc should be green, reverse is red. Check that and if OK. Recalibrate your controller to the esc Hang up and Drive |
02-06-2019, 10:26 AM | #1051 | |
Starting to wonder if somehow it's got a throttle curve, and it doesn't show it? Gonna try resetting to stock, if that doesn't work, I may have to try a different radio and see what happens. Sent from my Pixel 2 using Tapatalk | |
02-06-2019, 10:35 AM | #1052 |
So I played around with the PWM frequency, it seems that it is only doing it when I have it set to dithered mode. Any other frequency, and it responds the way it should. Kinda strange, but if that's what it takes I will switch away from it LOL Sent from my Pixel 2 using Tapatalk |
02-06-2019, 11:33 AM | #1053 | |
Did you try another cable ? That’s a new one. Hang up and Drive | |
02-06-2019, 11:36 AM | #1054 |
02-06-2019, 01:14 PM | #1055 |
Many issues with sensored motors are due to the cable Hang up and Drive |
02-08-2019, 06:22 AM | #1056 |
Quarry Creeper Join Date: May 2009 Location: Scotland, UK
A question that's been puzzling me a little. If you have two motors, that are of the same design and one is 1500kv and one is 3000kv They are then installed in two identical trucks. The 1500kv is set to 100% throttle travel and the 3000kv is set to 50% throttle travel on the transmitters what will the difference be in performance under load and will the rpm of each be the same in real world use if driving on the flat and not geared too long. |
02-08-2019, 07:53 AM | #1057 |
Your 3000kv set to 50% will create 4x the conductive heat in the esc plus diode losses (if the esc doesn’t active freewheel) for the same load. Otherwise, nearly identical performing.
02-08-2019, 07:55 AM | #1058 | |
That’s very strange and I have no solution! Besides maybe rolling firmware back and forwards. | |
02-08-2019, 08:00 AM | #1059 |
02-09-2019, 08:16 AM | #1060 |
Newbie Join Date: Jan 2019 Location: Ontario
Bought a puller pro to go along with a Mamba X. Question I have is whether to use full sensor mode or smart sense mode? Which is recommended and provides the best performance and motor control? Thanks
Have tech questions? Will answer. - Similar Threads | ||||
suspension tech questions. | Gen3_Teg_88 | General Crawlers | 9 | 07-13-2018 08:29 AM |
axle tech questions | 808eng_rc | Multi Axle Rigs | 4 | 11-07-2013 02:08 PM |
(HH) Tech Questions and Customer support thread | JohnRobHolmes | Holmes Hobbies | 3483 | 02-05-2013 09:08 PM |
2 stupid newbie questions needs answer | Mysterious | Axial XR10 | 21 | 06-18-2012 09:22 AM |
? Who has the answer to thes questions ? | mik236 | Team Losi Comp Crawler | 12 | 05-23-2010 02:40 PM |
