09-09-2019, 02:51 AM | #1421 | |
| Re: Have tech questions? Will answer. Quote:
Sent from my SM-N950U using Tapatalk | |
09-09-2019, 03:12 AM | #1422 |
Quarry Creeper Join Date: May 2019 Location: North Highlands
| Re: Have tech questions? Will answer. |
09-09-2019, 05:51 AM | #1423 |
Quarry Creeper Join Date: Mar 2018 Location: Indonesia
I love my Revolver 1800KV motor as well but I would advise using it with a Mamba X for the aux wire function. If I'm bashing in crawl mode the sound when the drag brake comes in is harsh. No problem when crawling however. I use a 9T pinion on my TRX-4 so I would imagine that the 1400KV would have been pretty close to fast enough on 3S with the stock 11T pinion. Even with 2S the Revolver seems to have plenty of power. Sent from my LG-H870DS using Tapatalk |
09-09-2019, 06:53 AM | #1424 |
| Re: Have tech questions? Will answer. A crawlmaster pro is a little more active motor, it will make more power and have more area to dissipate heat. The Magnum starts extremely smooth and has better torque density and drag brake. Either one is a mighty fine choice. If you aren't limited in mounting length or trying to save a little weight, the 550 will perform very well. |
09-09-2019, 07:00 AM | #1425 |
Magnum is crawling found here https://youtu.be/e_Yt8ijcwFg?t=1382 |
09-09-2019, 12:14 PM | #1426 |
Quarry Creeper Join Date: Nov 2018 Location: Mexico, Guadalajara
My ESC fails in contact with water, I have the Holmes Hobbies TrailMaster BLE Pro pretty annoying because I can't follow other guys. even a small splash makes the ESC fail Could you recommend a tutorial for waterproofing do you know if MG Chemicals Silicone Modified Conformal Coating may help for waterproofing? |
09-09-2019, 12:47 PM | #1427 | |
RCC Addict Join Date: Jun 2017 Location: Canada
You can also use clear nail polish. I use it on anything electronic that has to stay outdoor like garden lights, speakers, switches, etc. It prevents the boards from rusting and oxidizing. You can even put the nail polish on solar cells to prevent the plastic from oxidizing and becoming opaque and whiteish Sent from my Pixel 2 XL using Tapatalk | |
09-12-2019, 05:07 PM | #1428 |
Pebble Pounder Join Date: Aug 2011 Location: phoenix (Ahwatukee)
Hey John, I settled on a revolver and Mamba X. However I am getting a lot of cogging. Much like this video I found : https://youtu.be/6SOR6HMPQZM. Its on a scx10.2 stock spur wit 12t pinion. I'll admit I have not gone in and set up the ESC with a castle link yet (don't have one yet). Will a throttle curve and other settings shown on your youtube video fix this issue or do I have something else wrong? |
09-12-2019, 05:10 PM | #1429 | |
09-12-2019, 08:36 PM | #1430 | |
Pebble Pounder Join Date: Mar 2012 Location: Fort Collins
A throttle curve will definitely help but I am curious, since you got the Mamba X why didn't you get a sensored motor to go with? That will have the biggest effect towards eliminating cogging... | |
09-12-2019, 10:21 PM | #1431 | |
I have zero cogging on a 3S (sometimes 4S) powered Bomber running the 1800kv Revolver and a Mamba X. I used the setup shown in the Holmes Hobbies YouTube video - works like a charm: | |
09-13-2019, 01:49 AM | #1432 |
I had to go into the settings with castle link, now it works great. The only thing I noticed is it pulled my battery down real fast.
09-13-2019, 08:24 AM | #1433 |
Excellent video, thanks for the link Durok, glad you got it all sorted Strap624...
10-19-2019, 11:09 AM | #1434 | |
Newbie Join Date: Oct 2019 Location: Cortlandt Manor
10-19-2019, 03:51 PM | #1435 |
Quarry Creeper Join Date: Jun 2018 Location: CRG
I'm building a crawl-focused SWB Bomber that should be about ~8# with a tubular SS chassis , AR44's (OD front), and a Wraith tranny wih dig. I'll be running 4s with a BRXL and a CM Pro 550 12T. What Spur/Pinion combo? Preferably 48P, I think. |
10-19-2019, 05:07 PM | #1436 | |
10-19-2019, 11:31 PM | #1437 |
10-20-2019, 04:18 PM | #1438 |
Newbie Join Date: May 2008 Location: Gold Coast, Australia
I have a HH Puller Pro and a HH BLE Pro, I had them in an Axial SCX10.2 and have taken them out and put them in my Associalted Sendero kit. When I set it up forward was reverse and vice versa, so I reversed the settings on my Spectrum radio. The issue I have is the settings are all reversed, eg, I have 50% forward and 100% reverse. How do I fix this???
10-20-2019, 05:37 PM | #1439 | |
Pretty sure the Enduro transmission rotates reversed from normal. On mine, I just swapped the motor wires - but that's with the stock brushed setup. Don't swap wires on a sensored brushless! | |
10-20-2019, 07:23 PM | #1440 | |
Quarry Creeper Join Date: Apr 2018 Location: US
Sent from my Pixel 2 using Tapatalk | |
Have tech questions? Will answer. - Similar Threads | ||||
suspension tech questions. | Gen3_Teg_88 | General Crawlers | 9 | 07-13-2018 08:29 AM |
axle tech questions | 808eng_rc | Multi Axle Rigs | 4 | 11-07-2013 02:08 PM |
(HH) Tech Questions and Customer support thread | JohnRobHolmes | Holmes Hobbies | 3483 | 02-05-2013 09:08 PM |
2 stupid newbie questions needs answer | Mysterious | Axial XR10 | 21 | 06-18-2012 09:22 AM |
? Who has the answer to thes questions ? | mik236 | Team Losi Comp Crawler | 12 | 05-23-2010 02:40 PM |
