02-24-2020, 01:32 AM | #1661 | |
Rock Stacker Join Date: Oct 2019 Location: Van down by the river
| Re: kV change vs.pinion size Quote:
I’d also consider how ‘slow’ is slow for your situation. Personally, I can’t seem to gear low enough hahaha! THAT kind of low speed control on climbs/descents is incredibly fun. | |
03-02-2020, 11:28 PM | #1662 | |
Yes there is an equation. Basicaly if you double the kv remove half the pinion teeth. __________________________ Handy gearing spreadsheet Last edited by Voodoobrew; 03-02-2020 at 11:33 PM. | |
03-03-2020, 10:07 AM | #1663 | |
Pebble Pounder Join Date: Mar 2012 Location: Fort Collins
Thank you Voodoo, I sent a request to use it and then noticed you left the bottom line editable for use. Thanks again, Ed | |
03-03-2020, 05:42 PM | #1664 |
| Re: Have tech questions? Will answer.
If you save a copy you can edit it, just not the grey lines. The second tab has more info too when you get comfortable in the first. __________________________ Handy gearing spreadsheet |
03-03-2020, 08:50 PM | #1665 | |
| Re: Have tech questions? Will answer. Quote:
That's what I ended up doing,thank you very much, now I just have to figure out the 3-gear transmission reduction in relationship to the fixed size spur and what motor pinion I am using. Get a bit confusing, I know the transmission takes what pinion I am using with the spur gear and reduces it 2:1 just not sure how to factor in the pinion/spur combo to that reduction. | |
03-04-2020, 07:03 AM | #1666 |
The million dollar question...when will your SHV500V3 servo be in stock? Is it going to be delayed by the Coronavirus?
03-04-2020, 11:01 AM | #1667 |
Rock Crawler Join Date: Dec 2005 Location: East Texas
| Re: Have tech questions? Will answer. |
03-05-2020, 06:25 AM | #1668 |
03-05-2020, 04:43 PM | #1669 |
Quarry Creeper Join Date: Jun 2004 Location: Louisville
How do you attach the blue and yellow leads on an Apex motor?
03-05-2020, 05:59 PM | #1670 | |
__________________________ Handy gearing spreadsheet | |
03-14-2020, 07:58 PM | #1671 |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
HI I have your 35t holmes pro hw crawler motors on my berg, they have been Awesome ! It has Dual micro mamba micro , then ditched my diy relay dig for a wantAmix but never could figure out how to set up the WantAmix dig controller. So since that was like 7 yrs ago, I miss my berg and I'm thinking of ditching the wantAmix and either trying HeyOK DIG or going back to single ESC, but I'd really like to run full dig function So what do you recommend? add a heyok dig go back to single esc can I send to someyone to fix it all? I have had much life setbacks last few yrs and I just cannot figure out this stuff anymore. Transmitters: I have my Custom Pistol DX6i , a DX3R and my new DX6 stick using for my quadcopter. rx: i have ar500, 6ch 6100. Thank You Last edited by toy4crawlin; 03-14-2020 at 09:30 PM. |
03-16-2020, 05:08 AM | #1672 |
You Have 2 esc's you don't need a dig, you need a remote that handles 2 esc's like the Spektrum dx5pro. Futaba makes them too but I don't know Futaba. No idea how your dx6i pistole functions, but basically you bind ch2 and ch3 together to be throttle in one screen and set 1 dial/switch to change the % of throttle between them in another. 100 only the front moves, 0 they both move, -100 only the rear moves. It's all in the remote programming, I imaging if you hacked a dx6i into a pistol, some how you can figure it out.
03-17-2020, 10:55 AM | #1673 | |
Rock Stacker Join Date: Oct 2009 Location: mitchill
03-17-2020, 11:26 AM | #1674 | |
Newbie Join Date: Jan 2020 Location: Warner Robins
Thanks for the information I have been looking for info like this and glad I found it! Sent from my iPhone using Tapatalk | |
03-19-2020, 12:54 AM | #1675 |
Newbie Join Date: Mar 2020 Location: Canada
| Loss of power
Hey I have this problem where when my truck is facing a wall, the motor stops turning as if it loses power Any help would be appreciated |
03-20-2020, 08:17 AM | #1676 | |
| Re: Loss of power Quote:
Does the entire system shut off, just the motor, or is the motor simply too weak to take the load? | |
03-20-2020, 10:14 AM | #1677 | |
It's a scx10.1 everything is stock The motor doesn't turn at all when facing a wall Sent from my iPhone using Tapatalk | |
03-20-2020, 10:34 AM | #1678 | |
I wonder, which model is it and did the throttle get turned down? A throttle % switch was on some Tx's and if thats at50% the rig will not have much power, esp on 2s. | |
03-20-2020, 10:37 AM | #1679 | |
Alright I'll check on that Thank you Sent from my iPhone using Tapatalk | |
03-21-2020, 06:55 PM | #1680 |
Hello, I have a hopefully simple question, I have a CC 2.0 WP-BEC using it at 6v (this version has 2 out put legs each at same voltage), on one leg is power Led Light Bars and the other leg is power 2 fans. I want to add a switch to the fans so that I can turn them on or off as needed. I have a few older Novak on/off switches that just brake the circuit on one wire. Does it matter if I put it on the positive or negative leg? It will be in-between the BEC and the fans so lights will still function normally on the second leg. Thank you guys and gals, Ed
Have tech questions? Will answer. - Similar Threads | ||||
suspension tech questions. | Gen3_Teg_88 | General Crawlers | 9 | 07-13-2018 08:29 AM |
axle tech questions | 808eng_rc | Multi Axle Rigs | 4 | 11-07-2013 02:08 PM |
(HH) Tech Questions and Customer support thread | JohnRobHolmes | Holmes Hobbies | 3483 | 02-05-2013 09:08 PM |
2 stupid newbie questions needs answer | Mysterious | Axial XR10 | 21 | 06-18-2012 09:22 AM |
? Who has the answer to thes questions ? | mik236 | Team Losi Comp Crawler | 12 | 05-23-2010 02:40 PM |
