03-29-2020, 11:21 PM | #1701 | |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
| Re: Have tech questions? Will answer. Quote:
further troubleshooting I did was I just gave up on using the throttle channel and moved to rudder, it worked, esc calibrates and arms, no more motor beeping. New issue , Since many of us old schoolers change the pinions gears so that that the front has a slight over drive than the rear How do you make the rear slightly over drive in reverse but yet remains slightly slower than front when going Forward? | |
03-29-2020, 11:23 PM | #1702 | |
Rock Crawler Join Date: Dec 2005 Location: East Texas
Check this out, from Voodoobrew (posted above me here) Great calculator, and gearing info in general. https://docs.google.com/spreadsheets...#gid=453959559 | |
03-30-2020, 11:33 AM | #1703 |
Rock Crawler Join Date: Nov 2019 Location: Erie
I’m looking for a new esc/motor combo for my Losi Comp Crawler. I’m really interested in the new V2 Puller Pro motors, especially the 2700kv stubby. Is the Castle Mamba X the best esc to pair with this motor? I’m not crazy about the high pitch noise of the Mamba X but would be willing to live with it. Thanks fellas!
03-30-2020, 11:35 AM | #1704 | |
Newbie Join Date: Jan 2016 Location: great falls
I am running the hobbywing 1080 brushed esc Sent from my SM-N960U using Tapatalk | |
03-31-2020, 03:59 AM | #1705 |
Rock Stacker Join Date: Jan 2020 Location: OH
I have been running a PP V2 2200kv with a mamba x, and just put in a 1800KV revolver and cant get any low speed control out of it. I have been playing with the curve, but it seems to just make more noise longer with a long slow ramp. Once the motor starts turning, it's just too fast of a crawl. Any ideas on setup would be welcome....Thanks! |
03-31-2020, 05:32 AM | #1706 | |
__________________________ Handy gearing spreadsheet | |
03-31-2020, 10:19 AM | #1707 |
[QUOTE=Voodoobrew;6009186] But in moa I find it's not necessary since when you need overdrive is when your climbing and the rear is loaded up. Because the rear is loaded up it will spin slower on its own. QUOTE] I’ve got a Futaba for my MOA, and I proportionally adjust the rear motor from 110 down to 10. This is all part of the dual esc mix Hang up and Drive |
03-31-2020, 08:42 PM | #1708 | |
Hopefully this snip of my Bomber / Mamba X / Revolver v1 1800kv settings is helpful with whatever rig you are running. I am using stock 64t spur/12t pinion and usually 3S LiPo, sometimes 4S - and the Bomber is very heavy as it's pretty upgraded. It crawls at a snail's pace, drag brake is very strong when I have it turned on with the 3rd channel controlling the Aux Wire function: | |
04-01-2020, 05:55 AM | #1709 |
Newbie Join Date: Mar 2020 Location: US
I have a vanguard ae3 ESC and it blinks yelow and green after start up do you know if that's just a low voltage light it on my yeti I'm new to this world and already love it so I'm hoping that's all it is . The hole circus is making things hard to get like chargers and batteries so I'm patiently waiting for my new things just try to figure out if I broke the yeti or it's just a low battery Sent from my ONEPLUS A5010 using Tapatalk |
04-01-2020, 12:19 PM | #1710 | |
04-01-2020, 12:37 PM | #1711 |
Hey I feel like this is extremely simple but I want to confirm. I see a lot of motors that have a 1t or 35t even 55t which from what I have gathered is the turn of the motor. That being said, as the turn goes up does the torque go up or down? I know the high the turn the more wheel speed, but I'm more looking for good torque but not concerned for speed I was looking at a pro crawler 11t from holmes hobbies. Sent from my SM-N960U using Tapatalk |
04-01-2020, 12:57 PM | #1712 |
RCC Addict Join Date: Jun 2017 Location: Canada
Lower turn = more speed and slightly less torque Sent from my Pixel 2 XL using Tapatalk |
04-01-2020, 01:03 PM | #1713 | |
04-02-2020, 12:38 PM | #1714 |
Newbie Join Date: Jan 2019 Location: US
I have a mamba x with a puller pro and have no reverse the sensor wire that came with it is bad i replaced it and the motor runs smooth now with no reverse running sr515 with rugged radio and no reverse Sent from my SM-G975U using Tapatalk |
04-04-2020, 04:15 PM | #1715 |
Hi I just got a e Revo and the thing hesitates and go in reverse sometimes when it wants to but it es hesitates hesitates hesitates then it will go and then all of a sudden it comes out of it and it has full power will do that for a little bit and then when I stop it it'll start hesitating again will not take off at full power ever please help I also have a yeti that I just rolled and now it just doesn't move like something found in it just jerks jerks jerks wants to go but doesn't go Sent from my ONEPLUS A5010 using Tapatalk |
04-06-2020, 09:13 AM | #1716 |
Is it the 2 second reverse delay thats programed into the ESC for racers? Many esc's ship like that. double taps provide faster reverse sometimes. Usually you can reprogram them into crawler mode to remove it, but that can destroy gears or electronics.
04-06-2020, 05:19 PM | #1717 |
I got a question for you guys....so I want to hook up a single servo to 2 different channels on my remote. Can this be done?
04-06-2020, 10:29 PM | #1718 | |
What is the goal here? Will you be able to isolate the signal independently, so the servo doesnt get twitchy reading to different signals? could try it with a Y splitter cable but just use 1 input power. | |
04-06-2020, 10:33 PM | #1719 |
Hi John Question I have your BR XL Dual ESC's and want to know why are folks adding a BEC for there servo . when your ESC already provides " 5 amp 6 volt on board switchmode BEC delivers unbelievable servo power at any input voltage. " Do I really need one? Also, what are the dangers of removing the heat sinks? are there instructions/video on how to strip down the esc's to make them compact? Thank YOu |
04-07-2020, 05:45 AM | #1720 | |
I don't know if the channels are constantly putting out signals or only when they are being used? Maybe Ill need a diode to keep the signals from back feeding? I was just wondering if anyone has tried it or knows if it will work/wont work and what needs to be done. | |
Have tech questions? Will answer. - Similar Threads | ||||
suspension tech questions. | Gen3_Teg_88 | General Crawlers | 9 | 07-13-2018 08:29 AM |
axle tech questions | 808eng_rc | Multi Axle Rigs | 4 | 11-07-2013 02:08 PM |
(HH) Tech Questions and Customer support thread | JohnRobHolmes | Holmes Hobbies | 3483 | 02-05-2013 09:08 PM |
2 stupid newbie questions needs answer | Mysterious | Axial XR10 | 21 | 06-18-2012 09:22 AM |
? Who has the answer to thes questions ? | mik236 | Team Losi Comp Crawler | 12 | 05-23-2010 02:40 PM |
