10-13-2017, 05:03 AM | #1 |
Rock Stacker Join Date: Jan 2017 Location: Australia
| Axial ae5 esc lipo cut off not working.
I got a second hand bond and my 4 year old son uses it mostly. He has driven it till its stopped and in doing so has dropped 2 3s lipos to well below 9v total, around 2.4v each cell. Batteries are gone I assume but my question is. Is the esc all so gone and I replace it? If so I have another old ae5 I can swap it for but also have a brand new hobbywing 80A crawler brushed esc I can put in. What my best option. Thanks Sent from my A1601 using Tapatalk |
10-13-2017, 05:04 AM | #2 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
| Re: Axial ae5 esc lipo cut off not working.
If you already have the 1080, why not stick that in?
10-13-2017, 05:05 AM | #3 |
| Re: Axial ae5 esc lipo cut off not working. |
10-13-2017, 05:42 AM | #4 |
RCC Addict Join Date: Jun 2016 Location: Germany
did you setup the ae5 for lipo? its just a jumper on the esc. cause it sounds like it's setup for nimh instead of lipo. here a link to the instructions http://docs.axialracing.com/instruct...Drag_Brake.pdf |
10-13-2017, 06:05 AM | #5 | |
| Re: Axial ae5 esc lipo cut off not working. Quote:
Sent from my A1601 using Tapatalk | |
10-13-2017, 06:10 AM | #6 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
This seems to be a recurring theme with Hobbywing ESCs. I read a thread recently where somebody was having the same problem with one of the brushless ones, and I've had the same problem with a couple of my Hobbywing clone ESCs (X-Car 120A), and with one of my Hobbywing ESCs. In my case and in the case of the other thread I was reading, the cutoff is kicking in too early, but none the less, it seems fairly common for the Hobbywing ESCs to have cutoff issues. If the ESC is otherwise functional, I'd just get an external alarm and call it good. I tend to prefer the external alarms anyway, because it always seems like my cutoff would kick in when the car is a mile away from me or in a hard to reach spot. With the alarm, at least I can drive it back to me. |
10-13-2017, 06:23 AM | #7 | |
10-13-2017, 07:04 AM | #8 | |
People may not like the cut-off levels of the HobbyWing ESCs, but that doesn't mean they don't work. The AE-5 is a POS. Trash it and put in your HobbyWing 1080. | |
10-14-2017, 09:27 AM | #9 |
Pebble Pounder Join Date: Feb 2016 Location: Shelby
The problem is your son drove it till it stopped. Lvc hits and drops throttle to 50%, being only 4 he wouldn't notice the slow down. I've done this myself and had to rez my batteries with nimh mode on my charger. Easiest way to check would be take a battery that's close to what lvc should be and see if the esc cuts power or not
10-14-2017, 07:32 PM | #10 |
10-14-2017, 07:43 PM | #11 |
10-15-2017, 01:42 PM | #12 | |
Axial ae5 esc lipo cut off not working. - Similar Threads | ||||
New ae5 esc from axial | Hodortime | Newbie General | 32 | 12-18-2016 11:11 AM |
Novak Brushless ESC lipo cutoff not working | S/X Runner | Electronics | 23 | 05-06-2009 06:55 AM |
