Thread: Venom pro2 connection break question
Old 10-23-2017, 07:06 AM   #1
Default Venom pro2 connection break question
I got a venom pro 2 charger and 3 venom 2400 7.2v lipo batteries. One battery gives me connection break every time I try to charge it. I have found if I plug one of the other batteries into charger and get to the confirm screen it will let me unplug that battery and connect the other (bad) battery and charge it. Can anyone explain what is going on
sgtwuebbles is offline   Reply With Quote
Old 10-23-2017, 08:02 AM   #2
Default Re: Venom pro2 connection break question
It’s testing, I suspect a bad charging lead, or a weak cell.
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 10-23-2017, 07:00 PM   #3
I have that charger. If your using the adapters they give you they really don’t work well. I just bought the whole wire with the proper connector that matches my batteries and it hasn’t happened since.
MattySlimz1987 is offline   Reply With Quote
Old 10-23-2017, 11:24 PM   #4
had a similar problem with my charger (not same), it was caused by a bad charging cable.
check your charger cable with a voltmeter if there is a break.
Gesendet von meinem T1-A21L mit Tapatalk
magic_yeti is offline   Reply With Quote
Old 10-23-2017, 11:32 PM   #5
has a similar problem with my charger, turns out my brother didn't plug in the battery properly.
MasteroFlego is offline   Reply With Quote
Old 10-24-2017, 06:14 AM   #6
Moderator
JatoTheRipper's Avatar
I had a Turnigy LiPo give me an error. Turns out that an internal connection must have broken because nothing fixes it. This is the first Turnigy failure I've had and it was after a hard hit so I don't blame HobbyKing at all. Something similar might have happened with your batteries.
Venom pro2 connection break question - Similar Threads
Hitec X1 or Venom Pro2 Awesome Kong84 Electronics 3 02-29-2016 02:21 PM
battery connection question pro mod steve Axial Yeti XL 7 04-21-2015 08:33 AM
Battery connection question EliminatorXR7 Newbie General 2 02-18-2015 06:46 PM
Connection Question from a Newbie grumpaw Electronics 7 12-31-2014 01:01 PM
Venom Charger (Connection Break) treday619 Electronics 17 04-13-2009 11:21 AM
