Thread: How a lipo drains
Old 12-17-2017, 08:56 PM   #1
Default How a lipo drains
So I'm running my HP 3 cell 1500mah battery, climbing up hitting the throttle , then , boom , its like the battery went from a 3 cell to a 2 cell, the speed changed, so my question is, do lipos discharge equally, or at one at a time ?
I've never witness that before or just didn't pay attention till now .
Frank211 is offline   Reply With Quote
Old 12-17-2017, 10:27 PM   #2
Default Re: How a lipo drains
Buy a lipo battery checker and find out if it is the battery, an individual cell, or not.
https://www.venompower.com/products/...lipo-batteries
DavidH is offline   Reply With Quote
Old 12-17-2017, 11:28 PM   #3
The cells should be discharging equally as they are wired in series. If it surges like that, your motor is probably pulling more amperage than that particular battery can supply and it may only keep up for a couple seconds (that is what a batteries "burst" rating is about.) What motor and esc are you using, and what is the C rating of your battery?
TheLetterJ is offline   Reply With Quote
Old 12-18-2017, 12:29 AM   #4
Are you sure your ESC isnt cutting back as it nears its low voltage cutoff? Some do that before shutting down completely
allanon1965 is offline   Reply With Quote
Old 12-18-2017, 01:02 PM   #5
I have a lipo checker not a venom , but it reads all about evenly
Old 12-18-2017, 01:03 PM   #6
The battery is 20c I'm running a HW 1080 paired with a HH silver can 550
Old 12-18-2017, 01:04 PM   #7
The lvc is fine , not stopping me at all
Old 12-18-2017, 01:05 PM   #8
Originally Posted by betty View Post
Poor guy. You need new lipos now.
Yes I do.... Need the funds first... I'm just making way with I have, you know
Old 12-18-2017, 01:12 PM   #9
Those batteries are rated at 30A discharge. Not much, def not enough for a 550 can... The esc probably went into limp mode (reduced power) due to voltage sag.
Ninomaniac is offline   Reply With Quote
Old 12-18-2017, 02:04 PM   #10
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Lipos dump really fast. One second it seems like they are just fine and the next they are pretty much dead feeling. Nothing out of the ordinary.
JohnRobHolmes is offline   Reply With Quote
Old 12-20-2017, 05:45 PM   #11
Ok cool , makes sense not enough power for a 550 can , very understandable....
Limp mode ,lol that's funny hearing that for a esc.
Old 12-20-2017, 05:50 PM   #12
Pretty much a dead feeling is what I got, sure felt like that...! Good to know nothing out of the ordinary with lipos...lol
Old 12-21-2017, 09:54 AM   #13
First off, the batt checker that tells you anything relevant will show internal resistance. Resting voltage doesn't mean much unless one cell is noticeably lower than the others after charging or discharging.
Second if you are discharging them to the point where voltage drops quickly, you're damaging your batteries. It's not like hitting it with a hammer, but you could go from 500+ charge cycles to under 50. The following pic gives you an idea. A lipo will still have "juice" for a crawler under 3.5v, usually down past 3.0v, but it internal resistance increases PERMANENTLY. If funds are an issue, then you can double your battery's life by discharging no farther than 3.7v & even more if you charge to 4.1v.
Only Chuck Norris can get away with discharging a lipo past 3.0v. But then again he only has to stare at it for a second to get it charged back to 5v/cell...
Hydrocarbon92 is offline   Reply With Quote
Old 12-21-2017, 12:59 PM   #14
Thanks for this diagram ,I have more of a understanding , thanks again .
Old 12-21-2017, 10:39 PM   #15
I like my packs at storage voltage when I'm done driving. Unfortunately, not many ESCs have such a high cutoff. But with a 5Ah pack I rarely end up below 3.8 anyway.
