01-03-2018, 07:09 PM | #1 |
Rock Stacker Join Date: Mar 2016 Location: Saskatchewan
| Anyone here an expert on the ESS sound systems?
First off. I have an older ESS One+. From what I can read online it says it has up to 30W of power...but the speaker it comes with is only 5W... so where can you get a better speaker? Also when I took it apart the place where the speaker was soldered too had another pad beside it...like it was possible to hook up two speakers. Does that one also have to be 4 ohm? The stock speaker is 4 ohm. The new ESS-Dual looks like it has the same ratings as the ESS-One...so I wonder if the dual just has a second speaker. On a semi related note...does anyone know where to find a good WATERPROOF speaker that is 4 ohm and small? While still being up to 15W of power? Thanks! |
01-03-2018, 10:54 PM | #2 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
| Re: Anyone here an expert on the ESS sound systems?
Just some notes... #1 a better speaker is not necessarily a louder speaker. A more powerful speaker is also not necessarily a louder speaker. i.e. a 500W speaker may be quieter with the same power output amplifier than a 20W one. It really depends on sensitivity (measured in dB/W/m and ranging in 80-100+ range). #2 my guess is that the speaker outputs are in parallel on the board. That means that if you hook up another 4 Ohm speaker, the ESS board will "see" a 2 Ohm impedance and that may overload the output chips. That's why some hifi and most car power amps are rated differently for different impedance (Ohm) speakers. Maybe a single louder speaker would be better. #3 where are you getting your Wattage data? I doubt that it can output 30W, and speaker ratings are... well, made up. A speaker doesn't "have" power, it can take power (some maximum before burning up). #4 now I'll let someone with actual experience with the ESS One chime in |
01-04-2018, 06:46 AM | #3 |
I have one of these in my King Hauler. Sitting on the bench the sound is not very loud, but it is made to be attached to a body or chassis, and uses that as a resonator for increasing the amount of sound that it puts out.
01-04-2018, 05:01 PM | #4 | |
| Re: Anyone here an expert on the ESS sound systems? Quote:
Anyone here an expert on the ESS sound systems? - Similar Threads | ||||
ESS-ONE Sound in a wraith | Markeje | Axial Wraith | 5 | 09-09-2015 02:57 PM |
Clodbuster cloding around ESS-ONE sound | shenlonco | Videos! | 0 | 04-25-2015 08:44 AM |
ESS ONE SOUND + Tamiya Rally = | shenlonco | Videos! | 0 | 01-25-2015 01:45 PM |
