01-05-2018, 07:24 PM | #1 |
Newbie Join Date: Nov 2017 Location: Manassas
| Older Airtronics 94358 with Spektrum DX5C
My son must have tapped the front pretty good on the bomber and the Savox SW0231 will need a gearset...;) I figured I would swap one of my trusty Airtronics servos but when I connect it to the receiver, the amber led goes out and the red led flashes...thus going into perhaps a "failsafe" mode? No throttle or steering unless I remove the 94358 servo lead. The red and black are in the same spot, blue on the other end.....any ideas? |
01-05-2018, 09:25 PM | #2 |
Rock Crawler Join Date: May 2016 Location: SoWIs
| Re: Older Airtronics 94358 with Spektrum DX5C
From what I know of Spektrum, that's the indicator that the receiver lost power recently while in use. My guess is the servo is shorting +V wire to ground, leaving enough voltage to run the receiver (1-2 volts) but not the servo/esc. When you unplug the servo, does the ESC go through the normal start-up beeps?
01-05-2018, 10:08 PM | #3 |
When I unplug the Airtronics servo, the amber receiver light will return within a few seconds and the red led will stop blinking, restoring normal operation . I also tried binding @ 22ms to no avail. |
01-05-2018, 11:57 PM | #4 |
Does the servo work with a different receiver, preferably a different model or even brand? Can you check if there's continuity between the servo's red & black wire? If it works on different receivers, all I can say is I've seen a multitude of people having problems with Spektrum & virtually every known brand esc/servo. |
Older Airtronics 94358 with Spektrum DX5C - Similar Threads | ||||
In Stock - New Spektrum DX5C Radio System! | RPP Hobby | RPP Hobby | 0 | 11-28-2017 10:40 AM |
Pre-Order - New Spektrum DX5C Radio System! | RPP Hobby | RPP Hobby | 1 | 10-27-2017 07:35 AM |
Older Spektrum Transmitter & Newer Receivers | Hardcoretam | Newbie General | 24 | 03-02-2017 09:27 PM |
airtronics 94358 question | yotachump | Electronics | 2 | 01-12-2008 04:56 PM |
