02-12-2018, 09:55 PM | #21 | |
RCC Addict Join Date: Jun 2017 Location: Canada
| Re: Best low cost ESC for 6pole sensorless motor?? Quote:
It was amazing for a sensorless motor but the noise from the revolver would drive me nuts over time! Sent from my Nexus 6 using Tapatalk | |
02-13-2018, 01:59 AM | #22 |
Rock Crawler Join Date: May 2016 Location: SoWIs
The main trick with sensorless is you can't overgear the motor, at least if you don't want much cogging. Also get the lowest KV Tenshock. Most vids I've seen were the higher KV, and people didn't like the lack of low-speed. It could also been the lack of EXPO on their TX. Speaking of outrunners, eventually I'll try a Turnigy 3542 1250kv outrunner in my Exo Terra. The vids I've seen show they are cog-free and still quick when geared up, but with absolute loads of torque. The outrunner noise definitely isn't soothing tho. |
02-13-2018, 03:29 AM | #23 |
Quarry Creeper Join Date: Feb 2018 Location: Melbourne Australia
This will have to do until the sv4 is ordered I have a stock slash 4x4 32p spur gear and slipper with an 11 tooth Pinion. I'M running the ssd high ratio transmission, and on 4s this thing fly. Best part is its still really good for low speed obstacles. Won't win and crawling comps, but is maximum fun! Motor is the tenshock 6 pole 1750 kv. Plastic is actually tape holding my cage together while the glue dries... (made a custom look) Sent from my LG-H870DS using Tapatalk |
02-13-2018, 08:36 AM | #24 | |
The hardware limitation is the gate drivers on the X. They can't do synchronous rectification. Variable frequency is already implemented. | |
02-13-2018, 02:39 PM | #25 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
| Re: Best low cost ESC for 6pole sensorless motor?? I would not recommend the X-Car ESC for sensorless use. It's terrible sensorless. I ran mine that way initially and couldn't figure out why there was a delay when accelerating from a stop. If you gave it full throttle from a stop, for the first 1/2 second or so, it would accelerate easy, then suddenly full throttle would kick in. It was almost like a really bad punch control, but I'd already eliminated all of that in the programming.Others mentioned that it exhibits that behavior in sensorless mode, and sure enough, when I put the sensor wire in, the problem went away.
02-14-2018, 10:10 AM | #26 |
| Re: Best low cost ESC for 6pole sensorless motor?? I saw that video, but the Holmes Trailmaster brushless ESC wasn't tested and I don't know if he had the SW4 on hand. I already have ordered a Revolver for my second Bomber build ( the lighter weight one with mostly kit parts)... And have a Mamba Monster X and a Mamba X. It's gonna be noisy!
02-14-2018, 10:24 AM | #27 | |
02-14-2018, 01:45 PM | #28 | |
02-14-2018, 02:15 PM | #29 |
RCC Addict Join Date: May 2015 Location: Price Twp.
| Re: Best low cost ESC for 6pole sensorless motor?? Saw the video, but I had the impression that was just with the revolver/sidewinder sensorless.
02-15-2018, 07:58 AM | #30 |
You saw the vid with the mamba X. The SW4 vid hasn't been uploaded yet.
02-15-2018, 11:37 AM | #31 |
| Re: Best low cost ESC for 6pole sensorless motor?? |
02-15-2018, 06:52 PM | #32 |
Quarry Creeper Join Date: Apr 2010 Location: Baraboo
Ive been running the Mamba MicroX for some time, & have a few HobbyWing BL1060 as well. The Startup of the HobbyWing is horrible compared to Castle.
02-16-2018, 04:43 PM | #33 |
Quarry Creeper Join Date: Jan 2017 Location: Olathe
JRH has posted his SW4 video for anyone interested https://www.youtube.com/watch?v=qzDSnR9UxaM |
02-16-2018, 05:09 PM | #34 |
Looks nice! Outrunners are not for me but it sure puts some pressure on the sensored setups for quality/price ratio. Would it work as good with another type of sensorless motor? Something like the HH trailmaster or hobbywing? Sent from my Nexus 6 using Tapatalk |
02-16-2018, 05:56 PM | #35 |
Quarry Creeper Join Date: May 2009 Location: Scotland, UK
Apart from things like the nicer case design and better low speed control are there any other features or performance enhancements?
02-16-2018, 08:03 PM | #36 |
| Re: Best low cost ESC for 6pole sensorless motor?? It's designed to run cooler and the design was changed to become part of the new firmware branch from what Robert said somewhere.
02-16-2018, 09:05 PM | #37 |
| Re: Best low cost ESC for 6pole sensorless motor?? I accidentally used my 1900kv Castle slate motor on a Mamba X sensorless for several months and didn't even notice until my coworker pointed out the sound. I had a bad sensor cable because I soldered together 2 cables because I needed a 375mm+ cable and I couldn't find anyone who sold a 400mm cable in America.
02-17-2018, 02:49 AM | #38 |
| Re: Best low cost ESC for 6pole sensorless motor?? I'm inching closer to my final configuration for the Bomber(s).... And yes, I am going to build 2, radically different Bomber-based vehicles - one go-fast, one crawler. Got all the parts I need and then some. I have enough interest in the uniqueness of the Revolver to build one outrunner Holmes, one inrunner Holmes, and of course will keep my Ascender running on the brushed 550 Holmes 21t w/the HW1080 ESC. Something about having one of each type of electric motor tech appeals to me. I may have just lost what's left of my mind, of course...... I'm still finessing some of the details... at this time I have a 3500kv PP, a 2200kv PP, and a 1800kv Revolver. For the ESCs I have one Mamba Monster X and one Mamba X. For servos I have a first-gen SHV500, and a ProModeler 470oz-in. I just scored a pair of SMC 3600 mAh 60C 4S LiPos for the Revolver, and I have a pair of SMC 4300mAh 40C 3S LiPos for the 3500kv Puller Pro. I also have one CC BEC 2.0 WP for the ProModeler. I'm currently eyeing a 4100kv "R" PP in my shopping cart over at the Holmes site... finger on the trigger, getting sweaty just thinking about it Probably selling the 2200kv PP, and who knows? Maybe the 3500kv as well... I certainly don't need 4 brushless motors for 2 vehicles! There are a couple tiny things arriving any day in the mail, and then it's ON, dammit. |
02-18-2018, 06:23 PM | #39 |
Rock Crawler Join Date: Jan 2014 Location: Granite Falls, WA
Encouraged by Holmes’ review of the SW4, I took advantage of RPP’s Presidents Day sale and ordered two of them, because I have several sensorless brushless outrunners which I’d like to use. I ran one, a Turnigy D3542, in my older SCX10 Jeep Unlimited, with an SV3, but didn’t like the performance I got out of it. Tried the same motor in my Wraith, also, with an MMP, and that yielded little more smoothness than when paired with the SV3. I’m excited to revisit this! I’m also thinking an SV4 + outrunner(or Tenshock 6-pole) would be good for reviving something like a Traxxas Telluride, or CC-01.
02-18-2018, 08:22 PM | #40 |
I'd be willing to try the SW4 - but... I'll be using a Mamba X because that's what I already have... and I'll be wanting to make use of the Aux Channel if possible. JRH seemed to think it worked pretty well with the Revolver! I am curious about whether the "BWD Motor Saver" brushed/brushless 540-size can cover that HH sells will work on the Revolver - if so, I'm curious what it might do to the sound it makes? Like I said, I'm experimenting. |
Tags |
6 pole, esc, mamba, sensorless |
Best low cost ESC for 6pole sensorless motor?? - Similar Threads | ||||
Low Cost, Reliable Micro Brushed ESC? | ajsmcs | Losi Micro-Rock Crawler | 13 | 10-14-2015 09:28 AM |
Sensored or Sensorless ESC/Motor combo | Lentsnh2012 | Axial Yeti | 6 | 05-26-2015 12:29 AM |
Low cost new look | ke6geu | Axial AX-10 Scorpion | 22 | 01-03-2014 02:39 PM |
Sensored motor + Sensorless ESC? | Army RC Crawler | Electronics | 6 | 02-12-2012 08:51 PM |
