02-12-2018, 10:14 AM | #1 |
Newbie Join Date: Feb 2018 Location: SoCal
| Radio took long to bind with receiver
Hello, I知 new to the group. Recently bought a used rig but I知 not sure why sometimes the radio doesn稚 bind with receiver. It took a good long min to make the first beep to able to drive forward or reverse. Thanks Sent from my iPhone using Tapatalk |
02-12-2018, 08:28 PM | #2 |
| Re: Radio took long to bind with receiver
Brands and models of the equipment may get a more informed answer, my friend... |
02-13-2018, 02:38 AM | #3 |
Rock Crawler Join Date: May 2016 Location: SoWIs
Are you sure you're not confusing the receiver binding with the ESC arming? If the ESC was calibrated for a certain neutral point and you accidentally adjusted the TX's trim too far, it may not arm til your trigger is moved a little. Most ESC's will beep/chirp at you thru the motor.
02-13-2018, 07:19 AM | #4 | ||
Ok thanks I値l give it a try Quote:
Trx4 with axial esc Sent from my iPhone using Tapatalk Last edited by THX_138; 03-16-2018 at 01:30 AM. | ||
Radio took long to bind with receiver - Similar Threads | ||||
Radio took long to bind with receiver | Socal3gs | Traxxas TRX-4 | 2 | 02-12-2018 01:52 PM |
Bind N Drive Receiver Question | ericinMD | Losi Mini-Rock Crawler | 3 | 02-11-2010 11:38 PM |
SR3100 Spektrum Receiver Won't Bind! | Tommy R | Electronics | 22 | 01-06-2010 03:17 PM |
