03-13-2018, 11:36 AM | #1 |
Quarry Creeper Join Date: Mar 2007 Location: winchester
| brushless esc / motor ?
not specific to crawlers I picked up a LOSi ten scte that has a like new ESC and motor. the ESC is a MSC-MXPRO. it visually looks the exact same as the castle mamba max pro. The motor is a 550 4pole 2800KV sensorless. My question for the wiser out there is, are these two speed controllers the same? if not... can i run a sensored 4300 KV motor with the MSC-MXPRO? would i be better off trying to sell the losi combo and just get the XR8 and 4300 combo? |
03-13-2018, 11:56 AM | #2 |
| Re: brushless esc / motor ?
Is this the ESC you have? Losi: 1/10 MSC-MCPRO Brushless ESC: Losi (LOSB9504) If so, the specs are as follows (taken from that page): Forward:Yes Reverse:Yes Brake:Yes Time Delay Brake:Yes Input Voltage:8.4V - 16.8V Input Connector Types:EC3 Output Connector Types:4.0 Bullet Plugs Motor Limit:No Limit (540 Size Motors) Length:1.85 in (47.0mm) Width:1.52 in (38.7mm) Height:1.27 in (32.2mm) Weight:2.83 oz (80.2g) BEC Voltage:Programmable PWM Frequency:12Khz Overload Protection:Yes Full On Resistance:.300 Ohms Wire Gauge:13AWG Auto Cutoff:Yes But if you open up the manual, found here: http://www.losi.com/ProdInfo/Files/LOSB9504-Manual.pdf It says: Specifications Motor Type Sensored and Sensorless Brushless Low-Voltage Cutoff Automatic Detection Input Voltage LiPo 2–4S or 8.4V–16.8V Full On Resistance .0018 Ohm Motor Limit 4.5T 550 Sensored Motor Output 13AWG Lead AWG Motor Connector 4.0mm Bullet Plug Battery Input 13AWG Lead AWG Battery Connector EC3™ Type Dimensions 45.5 x 36.5 x 21.5mm (1.79 x 1.44 x .85 in) Weight 81 g (2.8 oz) (without wires) BEC Output 5.5–7.0V Turn to kv isn't a direct correlation and manufacturer specs vary so you are getting close to the limit with a 550, 4-pole 4300kv motor. |
03-13-2018, 12:00 PM | #3 | |
| Re: brushless esc / motor ? Quote:
yes thats the ESC i have. | |
03-13-2018, 12:08 PM | #4 |
| Re: brushless esc / motor ? Brushless Motors this page makes it seem that a 4.5 correlates to a 9300.... but then i found this. so it seems i would be close to maxing out the ESC tekin 4.5t this is the motor I want to run with the losi ESC https://www.amainhobbies.com/hobbywi...401152/p580789 Last edited by intheworks; 03-13-2018 at 12:24 PM. |
03-13-2018, 12:23 PM | #5 | |
HobbyKing is another place you can go to check out turns vs kv. Their 4.5T 550 brushless motor is 4,550kv. https://hobbyking.com/en_us/turnigy-trackstar-sct-4-5t-sensored-brushless-motor-4550kv-550-size.html | |
brushless esc / motor ? - Similar Threads | ||||
Sidewinder esc and 5700 motor or Traxxas vxl 3s esc with brushless motor? | THE CRAWLER KING | Newbie General | 6 | 08-22-2010 07:10 AM |
