04-01-2018, 10:12 AM | #1 |
Newbie Join Date: Mar 2013 Location: Tennessee
| Throttle works upside down, but not rightsize up?
Hey everybody, Not as versed in the RC world as I once was, but having some odd behavior from a relatively new Axial Wraith RTR Poison Spyder with Tactic controller. I've only used it a few times, but have been using it to run my dog into exhaustion by driving end to end of a neighborhood field while he chases it. It started acting weird after a few rollovers -- losing throttle signal. Then it would only go if I was holding down the throttle and pushed it with my foot. Now throttle only works if it's upside down. Even if wheels are turning while I hold it upside down, they'll stop as I rotate it back to upright. Steering works fine. I can see ESC turn green when I press throttle, red when pressing reverse. 2C, 5000 lipo batteries -- tried two different ones and same thing. Any ideas? Last edited by dbungard; 04-01-2018 at 10:38 AM. Reason: typo |
04-01-2018, 11:41 AM | #2 |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
| Re: Throttle works upside down, but not rightsize up?
Have you tried turning it off and on again? Sent from my Nexus 5 using Tapatalk |
04-01-2018, 11:44 AM | #3 | |
| Re: Throttle works upside down, but not rightsize up? Quote:
I think I may have intermittent connection of some sort. I took out the screw holding the ESC from underneath, and moving it around just a few cm got signal to come back and everything to work fine again. Then when I screwed it back in, no signal again. I've been wiggling all the wires around and everything seems to be working again now. Weird | |
04-02-2018, 02:01 PM | #4 |
Rock Crawler Join Date: May 2016 Location: SoWIs
Swap the servo & ESC connectors & recalibrate the ESC. Aside from trigger moving wheels and wheel doing throttle, does it act the same? It could also be a hung or broken brush spring in the motor. Can you try a different motor? |
04-02-2018, 09:46 PM | #5 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
Since the ESC can "hear" the receiver, my guess is that trouble is in the ESC to motor area - bad connection somewhere or filthy brushes/broken springs. I had solder joints fail under the heatshrink a couple of times, looks fine, doesn't work, drove me crazy. Check everything from ESC to motor, don't be afraid to pull on the wires like you mean it |
04-02-2018, 10:16 PM | #6 |
bad battery connection if the rig has to reboot every time. bad ESC RX wire if it comes right back on or glitches. Bad motor connection if the ESC stays on and doesn't glitch out.
04-03-2018, 05:20 AM | #7 |
Newbie Join Date: Feb 2018 Location: Charlotte
All good trouble shooting ideas. Always start with the simple thing then move to the more complicated. Good luck |
04-03-2018, 06:13 AM | #8 |
| Re: Throttle works upside down, but not rightsize up? |
04-03-2018, 10:45 AM | #9 |
As I said, start with the basics Does it have power? LOL |
04-03-2018, 12:33 PM | #10 |
Dudes. He said in the first post that the green/red leds light up on throttle/brake. That means ESC -> motor problem. |
04-03-2018, 01:16 PM | #11 | |
Pebble Pounder Join Date: Feb 2016 Location: Manchester, NH
In short... Never overlook the obvious. | |
04-03-2018, 04:42 PM | #12 |
Start simple YRMV |
04-04-2018, 08:56 AM | #13 |
Thanks for all the inputs guys. I think I may have a bad connection to the motor. Under one of the heat shrinks is turning brown, like it's burning. The other is not
04-04-2018, 09:08 AM | #14 |
Throttle works upside down, but not rightsize up? - Similar Threads | ||||
Always Upside down | Dbx | Vaterra Twin Hammers | 95 | 05-26-2017 05:47 PM |
Help. Throttle controlling throttle and steering | andneverexhale | Electronics | 6 | 08-21-2014 07:46 PM |
Stock Wraith. Steering works. No throttle. | Matt Wright | Axial Wraith | 18 | 11-28-2012 03:56 PM |
steering bound up, and only full throttle works? | syber70 | Electronics | 3 | 01-27-2009 01:55 PM |
Axles upside-down? | smojoe | Tamiya TLT Crawlers | 1 | 04-18-2006 06:22 PM |
