problem with my crawler Hello I am new to the forums,But not the hobby. I have a axile deadbolt with stock electronics. and when it first turns on everything works perfectly fine but when i start driving it after 5 minuets or so the truck has extreme power loss. like no reverse power and like very slow forward throttle but if i turn it off and back on it works again for 5 minuets. If you could help thank you |
Re: problem with my crawler What battery are you using? Sent from my Nexus 5 using Tapatalk |
Re: problem with my crawler I tried all my batterys and it does the same thing. i think its the moter i am going to swap one in tonight |
Re: problem with my crawler Lipo or nicd batteries? |
I use lipos. Its 1 am so i cant test anything right now but i put a 27 turn race motor from a pan car in it and it seemed to fix it from testing it in my garage and front yard. so ill give it a real crawling/mudding test tomorrow. :) The new motor did not fix it I took the jumper and took it out of lipo mode and it works fine its really weird |
Re: problem with my crawler esc overheating and cooling down? |
Re: problem with my crawler The Axial AE-5 ESC is a piece of junk. Pick up a $16 wp-1060 from eBay (what I use), or better yet get a 1080 for $42. The latter has more settings and can power a medium-torque servo without an external BEC. https://uploads.tapatalk-cdn.com/201...3655f16215.jpg |
Re: problem with my crawler Quote:
