05-29-2018, 07:48 PM | #201 | |
| Re: Hobbywing Xerun AXE Quote:
JRH, all I gotta say is... I'm glad there are minds like yours working on this, I myself am smelling something burning - I think it's my synapses! | |
05-29-2018, 08:01 PM | #202 | |
There is a 3 phase stepper system I have been eyeballing. Has a 8000 rpm limit though, which would be like running a 700kv motor on 3s. That’s practically unusable for me. I want 30k to 50k from the motor | |
05-29-2018, 08:11 PM | #203 |
RCC Addict Join Date: Aug 2008 Location: Paulina
I think I’ll buy another HH motor just cause now.
05-30-2018, 06:25 AM | #204 |
So it doesn't have great low speed control, it isn't very efficient, it gets hot while braking, the motor lacks the power of other comparable motors, and it costs the same or more than the well known, high performance ESC/motor combos. What exactly is the upside here then? Last edited by svt923; 05-30-2018 at 06:46 AM. |
05-30-2018, 06:44 AM | #205 | |
RCC Addict Join Date: Jun 2017 Location: Canada
Exactly my thought... Hobbywing isn't some kind of cheap chinese offbrand, maybe they just went blind into something they don't have enough expertise? Looking at the stellar results from the hobbywing 1080, it's really disappointing... Quote:
05-30-2018, 07:11 AM | #206 |
Pebble Pounder Join Date: Oct 2006 Location: belgium, roeselare
at least they out bull-shited everybody.
05-30-2018, 07:25 AM | #207 | |
When you said you need to "throw it into a rig" I didn't know if that meant a test rig or a crawling rig. I still haven't received mine. Maybe I didn't get one before they went out of stock. Time to email them. | |
05-30-2018, 09:06 AM | #208 | |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
Sent from my Nexus 5 using Tapatalk | |
05-30-2018, 09:18 AM | #209 |
That was a bench test to get some metrics first. Today and tomorrow I'm testing on the rocks with 3 identical rigs running different electronics. I'm sure it will drive nicely, and this is what most people will care most about. It should be noted that the active brake doesn't actually pass current until the rotor is moved out of phase, and then pulls up to 0.3 amps. On any sort of slope or while the rig is controlling velocity, it will be burning 0.3 more amps. My average amp draw when crawling is right about 2.2 amps in a brushless rig, so it will only be about a 10-15% runtime hit. I'm mostly disappointed that the ESC is not sinus or FOC (aka torque vectoring) since that is what they are marketing with a fury. It simply is not, no matter how much I try to stretch the definition. The motor has a sinus bEMF. If the ESC was FOC, it would also have a sinus output to properly torque vector. The output of the ESC is 100% trap shaped and 6 step block commutation. This could kinda be FOC if the motor had trap bEMF, but it does not. The only thing that could be interpreted at FOC is that all three phases have voltage potential at the same time, but that is more for the velocity loop and active brake control. I'm sure it will drive nicely, although I've already driven velocity controlled ESCs and hate it so it won't stay in my rig. But to see so many terms thrown around in marketing that are simply false, it leads me to believe they are simply doing what chinese companies are known for. They say anything that sounds great that could get a sale. Super disappointing, I was really looking forwards to a sine drive or true FOC. FOC has a LOT of potential for eeking out efficiency at high rpm, or wringing out a lot of extra RPMs with exacting tolerance on how much hotter the motor will run (phase amp injection if you want to research it). I'll give it a good shake and compare runtimes, decents, throttle sensitivity, etc.. |
05-30-2018, 09:20 AM | #210 |
| Re: Hobbywing Xerun AXE |
05-30-2018, 09:23 AM | #211 |
Marketing often lies... I, personally, don't care about any of that. If it works and it works well then that's all that matters. I'm anxious to drive one. Why do you dislike velocity controlled ESCs? |
05-30-2018, 10:19 AM | #212 |
I like feedback of how hard the motor is working. If there isn't audible feedback, and there isn't a slowing of the vehicle, then there is nothing to tell me how much strain my driveline is under besides looking at the tire deflection. On an EV that I physically ride on the street, velocity control is fantastic. Amp control is great too, its similar to a gas engine's throttle. Voltage control works fine and is most typical. Get off road, and a velocity loop adds an insulating layer to what is going on, and I don't like that. Amp control is torque control, and that works fine off road , although it can be tricky to keep vehicle momentum steady and leads to more wheelspeed changes with varying torque needs. Just like a gas engine. Voltage control is more typical, and it is the most controllable and "tuned in" feeling of them all. You should care if a company lies on the marketing, if nobody holds them accountable then they will continue with absolutely false claims that suckers sales away from vendors that actually care about being truthful to a customer. How about an example. I have a battery with 200c TRUE™ discharge and although it is made in china I'm going to charge USA prices because it's soooo much better than the rest. 200% better by our metrics! What is TRUE™ discharge? It's totally different than average and burst rates, and you won't understand because it is very complicated. It also has nanometabeta particles that make it last a long time. Very long, in fact. You can test them out for yourself that it lasts "very long". How long is very long? Longer than most, we assure you. Terms are important. How would you feel if I had been selling my ESCs as FOC or sine wave for all these years and then suddenly it was found out that I was lying about it and they were the same trap drive that everybody else uses? Would probably ruin my reputation. But Hobbywing does it and who cares? I care. Motors and speed controllers are literally my life and I have to point this out when it is under my nose. It would be shady as hell to sweep it under the rug and simply try to sell them. I would be open to it, if Hobbywing would ever finish setting up my account. But I'll be up front with customers that most of the selling points are not just "fluffing", but straight up lies. |
05-30-2018, 10:37 AM | #213 | |
HobbyWing responded and said the systems will be available in 2 to 3 weeks. I see what you're saying, but the average customer, like myself, wouldn't be able to tell if a system was FOC or not. Sure you and other experts can tell, but for the rest of us it's simply a name. I get lied to every time I buy a car. Am I getting the gas mileage that's claimed? Nope. Do the tires last 35,000 miles? Nope. Do my cellphone batteries last as long as the manufacturer claims? Nope. Is my favorite brushless power going to spin up to the revs claimed by the manufacturer? Maybe. What average Joe tests that? The list could go on forever. Maybe those are different because they are theoretical claims versus reality, but in the end I don't think it matters much. | |
05-30-2018, 11:02 AM | #214 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
You'll most likely be happy with it. I spent a few minutes with it in a TRX-4 and liked it. I didnt get to do any real hard crawling with it though. John is going to be more critical of them for good reason. Hobbywing is a big company coming into his market and they are throwing around a bunch of high tech sounding terms. The vast majority of us have no way to test these like he does nor can we verify that the manufacturer is not embellishing or flat out lying. I'm glad he's actually testing them and giving the real tech info. The motor information he has provided is interesting as well. |
05-30-2018, 11:22 AM | #215 |
Rock Crawler Join Date: Jul 2006 Location: Hobbywing
Hi Everyone! I've been away from the forums for far to long...... but, if anyone has Hobbywing Q's, you can hit me up directly, Charlie@hobbywing.com, or through the contacts on HobbywingDirect.com just put "Charlie" in the subject line and it'll get directly to me! ;) I've driven this system for several months now, in many different conditions and loads. Now, clearly I'm super biased, that's not something I ever try to hide or mask, but, this system is amazing. Doesn't get super hot at all, does the "Lug by Lug" crawling, and has super fine ultra smooth response. All developed by Hobbywing in house. You can discuss or poke at the tech till you turn blue in the face, but the simple fact is, this thing drives amazing. When handed off to folks, they often did not know it was brushless, and asked me "What turn is this setup". When I explained, they needed to pull the body off for proof..... LOL. Point being if you guys have Q's about this for us, please send them my way, and I'll run it up the chain and get some official clarifications. This system is a full closed loop system, and the RPM of the motor is directly tied to throttle position. A normal setup basically outputs a motor signal, the motor response, and we adjust throttle input to match loads on the motor. The new system, will stay at what ever RPM you put it at, regardless of the loads on it. Uphill, or down hill. The down hill driving is amazing. So, I have a few vids of this system up now, and am currently working on a new run through of how "slow" this motor can go. Brought it out to Proline By the Fire, let folks wheel my own truck, and borrow a system, the responses extremely positive. Long time "Brushed only" drivers, were extremely impressed. Ya'll know me, I'm no expert super engineering guy, but I love RC, and I do it all the time. Feel free to email me anytime. I won't be able to stay on top of the Forum stuff, but I'm at my desk often and can always answer an email! ;) We've got samples out to testers now, and flood gates of "Real" information will start to flow soon! Thank you! Charlie@hobbywing.com (Formerly Charlie the Novak guy..... LOL. ) PS: you can check out my Youtube Channel for Hobbywing, "Hobbywing Official", and Check out "The Charlie Show" playlist. I think forums don't like links, so to avoid any post distress... lol, gonna leave the direct links out. It comes up right away with those search terms. Last edited by Charlie; 05-30-2018 at 11:32 AM. |
05-30-2018, 11:33 AM | #216 |
Very cool for you to come on the forum and post up your details, Charlie... I'm sure you'll get a lot of questions! There's an awful large group of us in love with the HobbyWing QuicRun 1080 ESC, so we have high hopes for the "Axe" system. However, we are pretty spoiled by Holmes and Castle for brushless - so how it all plays out will be quite interesting! BTW - I still remember how much I loved my Novak brushless (SS 5800?) that I installed in a heavily-modified Team Associated RC10T2, I even upgraded the rotor with a kit after running it ragged... |
05-30-2018, 11:44 AM | #217 |
Good to see you here Charlie. Hobbywing is very lucky to have you with them! If I am incorrect about any conclusions, please let me know. I'm pretty sure I understand how the system is working now, and it seems like a pretty slick method of laying an A/C waveform over the commutation to force it into sync speed. I'll be on the rocks where the real answers are |
05-30-2018, 12:31 PM | #218 |
RCC Addict Join Date: Nov 2014 Location: Nowhere
I think there's a place for both theoretical bench testing and real-world testing, but as JRH pointed out if the marketing used if dishonest then it should still be called as such, similar to the 100c batteries that make your Revo instantly go 70+ mph. It's kind of like on the mountain bike forums I go to where guys will argue for days over specific frame geometry and guess how the bike should perform before someone finally says "yeah I rode it and it feels pretty good". That said, I think my Puller 3500/BLE set the bar pretty high so I'll be interested to see if the AXE may be worth picking up.
05-30-2018, 01:27 PM | #219 | |
Rock Crawler Join Date: May 2018 Location: USA
05-30-2018, 01:47 PM | #220 | |
They have to handle English to French to German to Italian to Spanish and more, it gets funny real fast around the office | |
Hobbywing Xerun AXE - Similar Threads | ||||
Hobbywing Xerun SCT | norcallump | Electronics | 4 | 09-22-2015 11:17 AM |
hobbywing 150a xerun esc on 2s lipo | jvh22a | Electronics | 1 | 06-03-2015 09:52 PM |
Hobbywing xerun 3656 3400kv | Gvm23 | Electronics | 26 | 01-30-2014 01:23 PM |
Hobbywing xerun SCT pro | Cmarcan167 | Electronics | 3 | 01-18-2014 11:11 AM |
Hobbywing Xerun Sensored brushless combo. | Neeley | Electronics | 2 | 01-20-2012 04:47 AM |
