05-22-2018, 11:21 AM | #101 |
| Re: Hobbywing Xerun AXE |
05-22-2018, 11:29 AM | #102 | |
RCC Addict Join Date: Jan 2007 Location: Arkansas
| Re: Hobbywing Xerun AXE Quote:
I like power. Most of my trucks are geared low because it gets hot as balls here, so 4s really isn't crazy fast. Well, except 2nd gear in the trx4. That's just stupid fast for a scale but it's fun. | |
05-22-2018, 11:37 AM | #103 |
05-22-2018, 11:55 AM | #104 | |
RCC Addict Join Date: Aug 2008 Location: Paulina
Have you tried the Slate motors? Definitely not as strong as my Holmes PP but they are torquey and smooth with that latest firmware on the Mamba X. Also, Slate and MicroX combo for $150 if you want to stick with 3s or less like this HW. | |
05-22-2018, 11:58 AM | #105 |
| Re: Hobbywing Xerun AXE You know you can adjust the gearing as needed, sometimes the extra power is a big advantage. I would never consider running 2s again, but many of my trucks are not much faster than guys running a brushed 2s system.
05-22-2018, 12:02 PM | #106 |
A dozen posts from Harley in the last few days...
05-22-2018, 12:03 PM | #107 | |
When I said "good motors" I meant the higher end motors like HH, Team Brood, Tekin ROC412, etc. But for the record, no, I haven't tried a Slate motor. Obviously you can gear down - to a certain extent. I just don't understand why I'd overpower and then gear down when I get enough torque and wheel speed for my needs with 2S. Maybe I'll have to try it to understand it. | |
05-22-2018, 02:06 PM | #108 | |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
Sent from my Nexus 5 using Tapatalk | |
05-22-2018, 04:10 PM | #109 |
Evidently, telling people to volt up and gear down for over a decade still isn’t long enough. It reaps so many advantages in electrical systems
05-22-2018, 05:34 PM | #110 | |
05-22-2018, 06:10 PM | #111 |
| Re: Hobbywing Xerun AXE I've read it many times. But my electronics never get more than warm, I have enough power for my use, and my batteries last hours. What other benefits would I reap?
05-22-2018, 06:29 PM | #112 |
Rock Crawler Join Date: Nov 2014 Location: Dells
05-22-2018, 06:44 PM | #113 |
less waste heat at the same wheel torque and power, better startup, better drag brake, higher peak torque, more consistent vehicle during load changes and incline changes.
05-22-2018, 10:27 PM | #114 |
05-22-2018, 11:19 PM | #115 |
Quarry Creeper Join Date: May 2017 Location: Devon
05-23-2018, 02:29 AM | #116 |
Newbie Join Date: Jul 2014 Location: Germany
At what point does it stop to be beneficial to volt up and gear down, though? I guess one limit is that at some point you'd need additional gears for reduction. Another that more cells need more space and add weight. Is 4S the sweet spot for crawling (scale 1.9)?
05-23-2018, 03:03 AM | #117 |
Pebble Pounder Join Date: Oct 2006 Location: belgium, roeselare
Higher voltage = less amp draw, that inturn means you can run smaller cells. if the watt/hour of the pack is the same then you're good. |
05-23-2018, 03:45 AM | #118 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
Well, why so complicated? at the end you’re not compete in 24 Hours of Le Mans. |
05-23-2018, 05:28 AM | #119 | |
You sure about that? Wasn’t there a 24hour comp recently? Or was it a weekend long thing? Last edited by calcagno45; 05-23-2018 at 05:41 AM. | |
05-23-2018, 05:33 AM | #120 |
What is complicated? it's easy, more volts is more better |
Hobbywing Xerun AXE - Similar Threads | ||||
Hobbywing Xerun SCT | norcallump | Electronics | 4 | 09-22-2015 11:17 AM |
hobbywing 150a xerun esc on 2s lipo | jvh22a | Electronics | 1 | 06-03-2015 09:52 PM |
Hobbywing xerun 3656 3400kv | Gvm23 | Electronics | 26 | 01-30-2014 01:23 PM |
Hobbywing xerun SCT pro | Cmarcan167 | Electronics | 3 | 01-18-2014 11:11 AM |
Hobbywing Xerun Sensored brushless combo. | Neeley | Electronics | 2 | 01-20-2012 04:47 AM |
