Thread: Servo issue?
Old 05-17-2018, 02:19 PM   #1
Default Servo issue?
Hey folks, I was setting my castle link for my new Savox servo and I noticed that if I kept going back and forth between left and right very quickly it would end up stopping and then doing a few turns back and forth before functioning properly. Is it because Im going to fast and confusing the controller inside it? Is this brown out??? I have the 10a castle BEC on it and I run 2s. Its a HV servo.
Rekreant is offline   Reply With Quote
Old 05-17-2018, 03:54 PM   #2
Default Re: Servo issue?
That's a brown-out, the RX is resetting. I'd recommend using a bypass for your bec/servo and letting the ESC power the RX. It may not be dropping voltage but could get noisy, so a glitch buster might also help. OR just not stressing it beyond normal usage, lol.
Hydrocarbon92 is offline   Reply With Quote
Old 05-17-2018, 04:44 PM   #3
I do bypass the rx tho. I guess its cause im going back and forth too fast.
Servo issue? - Similar Threads
Servo issue? rockpunisher Electronics 4 04-10-2016 02:16 PM
Servo issue 09 Screw Axial Wraith 1 03-09-2014 01:21 PM
servo issue ax10tn Axial XR10 15 04-28-2012 07:20 AM
servo issue jetrod7024 Team Losi Comp Crawler 1 03-19-2011 11:27 AM
servo issue chuck-biscuits Electronics 2 03-08-2005 06:45 AM
