Powershift rc on/off switch Check this out https://www.ecwid.com/store/store114...R**-p108629997 : http://fs5.directupload.net/images/180618/5yqalxnu.jpg Harley talks about it here at the beginning https://youtu.be/0YGRhHBuJ2Y Cool lil device |
Re: Powershift rc on/off switch I something on this last night, looks interesting, it would be nice to leave the batteries connected and not have to worry about any discharge. I would want something more 'positive' holding it in so that it did not fall out from a hard fall, or become momentarily unseated and make the electronics cycle. |
Re: Powershift rc on/off switch Quote:
Re: Powershift rc on/off switch I'd think it would have to take a hard, direct hit to the switch to attempt to knock it out. In which if it is mounted in a proper spot like he demonstrated on the flat bed truck, a direct hit will be pretty hard to do IMO. Just don't lose the plug... |
If nothing else, I would want the block tethered. |
Wouldnt be hard to I wouldnt think |
Re: Powershift rc on/off switch $30 for a switch with a scale cover is a little salty, but I like the idea a lot. |
Re: Powershift rc on/off switch That's a lot more expensive than an extra XT60 added on your positive ESC lead. Then you can use much higher than 3S. Boaters route one wire near the hull, put a bulkhead female on the hull, then put a short wire loop on the female side. They simply give it a yank to disconnect the battery. I know Arrma does this for their ESC's to give people the option to use dual or single batteries. When you use a single, you insert the jumper. If you pull the jumper, the battery is disconnected. https://www.arrma-rc.com/power-systems/latest/blx185 https://cdn.shopify.com/s/files/1/10..._1024x1024.JPG |
Re: Powershift rc on/off switch WTF is the point of a switch? Failure points are great I guess? |
In over 30 years of RC I've had exactly 1 switch failure and that was this year with Castle's Mamba X ESC. |
Re: Powershift rc on/off switch Well I use a deans plug on my dead mans switch, not an actual switch. Switches on the ESC may or may not stop all amp draw so I don't use them. Most actual switches are rather large if they are rated to handle the amp draw. |
Re: Powershift rc on/off switch I'm not on FB so... Anyone know when Jon is planning to have more of these available? Amain shows out of stock on all three variations. |
Re: Powershift rc on/off switch |
Re: Powershift rc on/off switch Thanks so much.. The store didn't come up in my search. I appreciate it. |
Re: Powershift rc on/off switch My concern is how much resistance this thing adds. It looks like they might have a solid bar in the "battery" that's pulled onto the 2 body contacts rather than passing power thru the magnets' nickle plating...but we won't know til someone else reviews it. Hiding the workings of a $30 part is rather silly IMO. Quote:
Exactly, a typical ESC switch just turns off power to the on-board BEC. The power capacitors will still be charged and they still leak power (operational leakage current). It's not much, but a LOT more than a disconnected battery leaks. |
Re: Powershift rc on/off switch I was really intrigued by it since I'm planning on having a Marlin Crawler soon. I want it to be as scale as possible and not have to mess with the screws every time that I need to get inside. Still haven't seen any negative reviews but I see what y'all are saying for sure. I'm cautious but still plan to give it a shot. Wouldn't be the first time I blew $30 on something that didn't work as advertised. |
