07-06-2018, 02:59 AM | #21 |
| Re: Are you happy with your Savox 1230sg???
The savox1230sg was to loud for me. Laud to the point wher people wold say "oh I hear some one running a savox" every time I used it.
07-06-2018, 05:25 AM | #22 |
RCC Addict Join Date: Mar 2018 Location: Ocala, Florida, USA
I'm so glad I asked you guys before buying. I've been so back and forth with ask this servo stuff. I'm pretty sure I'm gonna go with the promodeler 470. Right now they're on back order, but I'm gonna send the link to the wife anyway. From what the website says they'll be back in stock mid to end of this month. Thank you guys again! I'll be going a comparison video of the power hd 20k & the promodeler once I get one. Have a great day!
07-06-2018, 05:52 AM | #23 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
If you like to play in mud and water like me. You would need waterproof servo. |
07-06-2018, 07:43 AM | #24 |
Quarry Creeper Join Date: Feb 2016 Location: canada
Its not that hard to conformal coat the savox 1230 ive done a couple of them Sent from my LG-M703 using Tapatalk |
07-06-2018, 08:41 AM | #25 |
Right now I have the steering link screwed to the outside hole on my apex servo horn. If I put it on the inside hole & reset my end points I should get a little more out of it, correct? Will it hurt anything by doing that? Sorry for the totally noob question
07-06-2018, 08:49 AM | #26 |
Ive killed 3 savox servos one over heated to the point it stoped working one just died out of the blue the other one stripped the gears replaced the gears and then it smoked out i think im gona jump on the promodler band wagon for my next round of servos i have some $4;servos ive been running for years on my clod crawler and some smaller rigs and there still holding strong after years of abuse but i did go through 7 of them befor i found 3 that lasted still cheap and i have lots of spare parts lol there tbe same gears that traxxass used i replaced the plastic traxxass gears with tower pro gears and it works great an a 12th scale
07-06-2018, 08:55 AM | #27 | |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
| Re: Are you happy with your Savox 1230sg??? Quote:
Eyeballing a reefs 555 as an eventual upgrade. | |
07-06-2018, 09:22 AM | #28 |
| Re: Are you happy with your Savox 1230sg??? Not big on the mud & water. I know that's how I use to tear up my 1:1 rigs all the time. Was a blast till it broke! Electronics & water is asking for something to break. I can't afford allot so I try to take care. If I fry something cause I was messing in water aka where I probably shouldn't be. I'd be pissed. Mud is allot of fun but I try to limit my time in it. Broken rig sitting on my bench = no crawl time. No crawl time makes for an unhappy Justin.
07-06-2018, 09:25 AM | #29 |
Conformal coating is cheap and will waterproof anything!! Way better then any plasti dip and you can get it from amazon Sent from my LG-M703 using Tapatalk |
07-06-2018, 09:41 AM | #30 | |
Here: | |
07-06-2018, 09:48 AM | #31 |
Im currently using the middle one lol. Works great i love the brush better then the spray Sent from my LG-M703 using Tapatalk |
07-06-2018, 10:13 AM | #32 |
Durok, here comes another noob question..... What's the use for each one? Sorry still new :-)
07-06-2018, 10:20 AM | #33 |
Quarry Creeper Join Date: Aug 2016 Location: Christiansburg
I have two 1230s in my 2.2 Wraith and Arrma Talion. Zero issues. They are noisy tho. And not water proof. But I packed mine with some dielectric grease and it goes swimming often enough. Take that as you want. |
07-06-2018, 04:38 PM | #34 | |
The middle stuff is the actual conformal coating, you can "paint" it on circuit boards inside servos to waterproof them. The silicone compound is silicone grease that is dielectric, adding a lubrication that does not allow arcing in electronic components - it won't hurt rubber or plastic either. You can put it on your electronic connectors such as those for your batteries, servos, motors, etc - and it protects against moisture and corrosion, too. Last edited by durok; 07-06-2018 at 07:58 PM. | |
07-11-2018, 05:07 PM | #35 |
Is the Promodler 470 a 25t drive?
07-11-2018, 05:21 PM | #36 |
Quarry Creeper Join Date: Nov 2015 Location: US
damn i have a 1231 i was going to use but reading this has me considering a return for something different
07-11-2018, 05:43 PM | #37 |
| Re: Are you happy with your Savox 1230sg??? |
07-13-2018, 10:44 AM | #38 |
Newbie Join Date: Sep 2017 Location: Austin
No complaints on my 1230sg. I plasti-dipped mine (sprayed on a few layers, shoe goo on the inside/outside servo wire opening) and done quite a few stream crossings. It only makes noise sometimes but its not bad. Much better than the stock servo on the TRX4 |
07-17-2018, 01:19 PM | #39 |
Rock Crawler Join Date: May 2014 Location: Cluj-Napoca,Romania
1230 is my go to servo for any aplications not runed in water.I don't mind the noise, if u want a quite place, go to the church |
07-17-2018, 02:08 PM | #40 |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
Are you happy with your Savox 1230sg??? - Similar Threads | ||||
Savox 1230sg | Tyler75 | Newbie General | 4 | 12-26-2016 03:06 AM |
Savox SA-1230SG servo | Jeepiac | Electronics | 10 | 09-24-2015 03:26 PM |
Savox SA-1230SG twitching? | ZackMicF | Electronics | 1 | 07-10-2012 10:19 PM |
