08-17-2018, 08:24 PM | #1 |
RCC Addict Join Date: Mar 2018 Location: Ocala, Florida, USA
| Drag brake not holding HW1080 in Trx-4
Noticed the other day my drag brake wasn't holding on an incline. I checked my HW1080 it was still set it at 100% hold. I checked through all the settings. Everything was set correctly. While I was running my rig yesterday I realized that it's still not holding. Is there some way to test the ESC? Is there something else that could be causing this? Still running stock Trx-4 motor/tx/rx. Any suggestions would be greatly appreciated
08-17-2018, 08:45 PM | #2 |
Quarry Creeper Join Date: Feb 2018 Location: Hoschton
| Re: Drag brake not holding HW1080 in Trx-4
Is it the trim on your controller?
08-17-2018, 09:53 PM | #3 |
Rock Crawler Join Date: May 2018 Location: USA
How old is the motor? Could be worn brushes.
08-17-2018, 10:04 PM | #4 | |
Quarry Creeper Join Date: Sep 2016 Location: Canada
| Re: Drag brake not holding HW1080 in Trx-4 Quote:
Sent from my EML-L29 using Tapatalk | |
08-18-2018, 08:21 AM | #5 |
Rock Stacker Join Date: Jan 2016 Location: NorthBay, Ca
Like Tralfaz ^^^ said, check Throttle trim.
08-18-2018, 11:37 AM | #6 |
How steep is the hill and what gear? In 2nd gear the drag brake will be a fair bit weaker due to the higher gear ratio. My drag brake wont hold me completely still on a hill but its strong enough to slow the rig down to a crawl as opposed to just coasting/freewheeling down. I have heard it said that the brake setting has an effect on how strong the drag brake is so you might try turning that up too. |
08-18-2018, 05:40 PM | #7 |
Newbie Join Date: Aug 2017 Location: Monroe, GA
I think HumboldtEF has what you need, it's the "Max Braking Force" if I remember correctly. There are 3 brake settings to play with, I just max one at at a time till I figure something on mine |
08-19-2018, 02:48 AM | #8 |
Quarry Creeper Join Date: May 2009 Location: Scotland, UK
What is the regular brake force set as? If it's set as something like 60% then the drag brake will also be set at 60% The drag brake setting is a percentage of whatever the regular braking force is set to I have the same motor and ESC in mines and i have some brass parts on my TRX-4 with a 9t pinion and with how heavy the truck is it won't hold mines in place on steep hills or similar either. |
08-19-2018, 07:19 AM | #9 |
Sorry guys haven't had time to dig into this issue yet. Been spending time with the family. Might get a few mins to look into it this afternoon. I'll keep you up to date when I do.
08-19-2018, 09:20 AM | #10 |
Quarry Creeper Join Date: Jun 2017 Location: Yavin 4
Mine hold decently, but the Titan 21t magnets are not as strong as the Holmes TrailMaster Sport. From what I have heard that motor has a lot more holding power....never seen that combo in person though. I have the titan and 1080 and I believe my max brake and drag brake are cranked all the way up. I think HumboldtEF nailed it, crank those up and if its still rolling back down. get it back up on that incline and fiddle with your trim knob till it holds better.
Drag brake not holding HW1080 in Trx-4 - Similar Threads | ||||
Brake vs. Drag Brake setting difference? | Lance Carbuncle | Electronics | 4 | 04-22-2018 07:33 PM |
Castle / AE-2 Drag Brake and Brake Power | ik632 | Electronics | 0 | 04-08-2012 07:47 AM |
Fxr brake not holding | Jay2380 | Venom Creeper | 10 | 04-28-2010 12:01 PM |
scx10 honcho no need for DRAG BRAKE?... already has drag... | yellowpasta2000 | Axial SCX-10 | 21 | 01-23-2010 09:28 AM |
Mamba Max drag brake not holding | ittybitty | Electronics | 25 | 03-07-2009 06:11 PM |
