08-19-2018, 10:46 PM | #1 |
Newbie Join Date: Aug 2018 Location: yucaipa
| Nimh batteries
I just got a Nimh battery and the people from the hobby shop said I would need to cycle the battery every 20th charge and to keep track of how many charges. He was fairly sure that I would be able to do this with my charger . I have an onyx 245 charger. I looked with out hooking up the battery on the charger and I didn't see a cycle feature. Do I have the correct charger to cycle batteries?
08-20-2018, 12:45 AM | #2 |
| Re: Nimh batteries
Why on earth did you get a nihm battery? Terrible batteries is what got me to put my rc stuff I storage 15 years ago and lipo got me to break it back out and I've been loving every minute of it since.
08-20-2018, 05:56 AM | #3 | |
Rock Crawler Join Date: Apr 2017 Location: Northeast PA
| Re: Nimh batteries Quote:
Having said that, Lipo batteries perform better and are a great upgrade when you're ready. | |
08-20-2018, 07:23 AM | #4 |
| Re: Nimh batteries That's not true. NiMH batteries can start fires and even explode! No battery should be neglected! |
08-20-2018, 08:01 AM | #5 |
| Re: Nimh batteries
Sure its possible, but they're a lot less volatile than Lipos. Edit: In hindsight, "safely tolerate neglect" was a poor choice of words. I meant it relative to Lipos where you need to think about balance charging, cutoff voltage, storage charge, etc. Last edited by TooOldForThis; 08-20-2018 at 08:25 AM. |
08-20-2018, 09:44 AM | #6 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
| Re: Nimh batteries
Seems a bit much to me... If you drain them until the truck won't move anymore and they're reaching approximately the capacity you expect on a charge I wouldn't worry about it too much. NiMH cells are a tough chemistry and won't suffer to badly if you aren't putting a lot of effort into maintaining them. I suspect that your charger can cycle as it appears to be lipo capable. The older NiCD chemistry batteries developed a 'memory' over time, whereas if you didn't charge / discharge them fully they would become weaker over time. I think you're guy was probably old school enough to have carried that forward. NiMH cells mostly fixed the memory issue, although some cells required some low amperage cycling (the GP 3300's come to mind) to reach their peak ratings or if they start to get a little flat. Last edited by Highmark; 08-20-2018 at 09:47 AM. |
08-20-2018, 09:45 AM | #7 | ||
I think it would be fair to say that NiMH packs do not need as much care and feeding as lipo packs. But, all batteries are stored energy, and require a requisite amount of respect. Last edited by Greatscott; 08-20-2018 at 09:48 AM. | ||
08-20-2018, 10:54 AM | #8 | |
Lipo is real easy to figure out. If someone cant grasp the simplicity of lipo when starting from zero then they will have a bad time in most aspects of rc. The tough learning curve is coming from nihm or nicd and thinking that lipo is like a supercharged version of them and then wondering why their junk is on fire. | |
08-20-2018, 11:01 AM | #9 |
Rock Crawler Join Date: May 2018 Location: USA
| Re: Nimh batteries
Try charging your nimh at 1C and tell me again how hard it is to start a fire with them lol. Nimhs are a waste of money in anything but double and triple A sizes.
08-21-2018, 12:12 AM | #10 |
| Re: Nimh batteries
Ok first of all I simply asked if I had the correct charger to cycle the NIMH batteries. Not what your opinions of them are. If you must know I run LIPO in my own car. This car is a older car that doesn't have a LIPO cutoff or warning. I don't want to put one on as this is an older car it's been discontinued I like to have it so when I take other people out that don't have cars they can drive something to. So i think i got that my charger could cycle batteries. Does anyone know how to cycle a battery with my set up. Once again I have an onyx 245. Any and all HELP would be great.
08-21-2018, 12:20 AM | #11 |
| Re: Nimh batteries
Perfect screen name choice. Yes I know, mine is that of a lowly trailer park dwelling sister fawker. The irony is if never lived in a trailer park and I don't have a sister. |
08-21-2018, 12:37 AM | #12 |
| Re: Nimh batteries
I actually got this nickname because I always used to throw kickbacks and I only had this snowflake light to light up the area where we were. Someone said I'ma call you snowflake and it stuck lol Oh and my real name is David is that close enough to dave? Lol Last edited by Snowflake; 08-21-2018 at 12:40 AM. Reason: Humorous purposes! |
08-21-2018, 04:38 AM | #13 |
| Re: Nimh batteries
Cycling the battery is just charging all the way and discharging all the way you dont need a special charger or feature to cycle the battery
08-21-2018, 05:58 AM | #14 | |
Granted, our delivery of that knowledge can be pretty crude. | |
08-21-2018, 09:45 AM | #15 | ||
Your poor brother! | ||
08-21-2018, 12:41 PM | #16 |
| Re: Nimh batteries |
08-21-2018, 01:01 PM | #17 |
| Re: Nimh batteries Good advice I'm fairly new to the forum if you haven't noticed lol
08-27-2018, 10:20 AM | #18 | |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
https://www.ebay.com/p/RC-Lipo-Batte...3539617&chn=ps As for NiMH, I think they do have their place. I trust my kids to recharge their own NiMH packs but I won't entrust them to recharge a lipo. NiMH packs are also great when I want to throw an RC into my truck to use later on. I don't like the idea of leaving a lipo in a hot truck. I'm sure they can tolerate 100+ degree temperatures without issue, but I'd rather not find out that they can't. | |
Nimh batteries - Similar Threads | ||||
Need help with NiMH batteries.... | T Bone 347 | Electronics | 6 | 04-02-2012 06:35 PM |
AA Nimh batteries | gcl1966 | Electronics | 3 | 03-07-2009 10:42 AM |
AA nimh Batteries | curve | Electronics | 8 | 12-27-2007 06:53 AM |
