09-09-2018, 11:06 AM | #21 |
Rock Stacker Join Date: Aug 2018 Location: Orlando
| Re: Reefs triple 5 not centering...
Heres a video... notice the difference at full extend on radio left to right. Only way to balance it out was to kick it over a tooth. .. It's not about str8 up and down. It's about equal steering length at the horn from a center point. http://cloud.tapatalk.com/s/5b9552f6...062217_320.mp4 Sent from my SM-G965U using Tapatalk Last edited by "MIS-TAKEN"; 09-09-2018 at 11:08 AM. |
09-09-2018, 01:41 PM | #22 | |
| Re: Reefs triple 5 not centering... Quote:
It really sounds like trim is not centered correctly on the tx/rx. Either you have purposely not left it centered, or it is not calibrated correctly. When the trim on the radio is centered and the steering horn is at 90° with out the steering link attached do you still have uneven swing? If yes: see if you can calibrate the steering on the radio (I don't think basic radios can do this), maybe it was calibrated with the trim set off centered. or maybe it is the servo is bad. If no: Then there is no problem with the radio or the servo, and the problem is with installation and setup, or your perception of what trim does. There is no rule that says put the steering horn on at 90°. I think it's doing this with that short upper steering arm is whats causing your issue. | |
09-09-2018, 02:02 PM | #23 |
What’s the total degrees of throw per specs Hang up and Drive |
09-09-2018, 02:05 PM | #24 | |
Dial 1 changes the maximum travel from center, to increase and decreas the steering radius. Dial 3 is trim and it offsets home from center, (note: it will not move the center of maximum travel, so if your servo travel is 90° center is 45°, if you adjust trim 10° home is now 35° and you can turn one direction 55° and the other direction only 35°.) | |
09-09-2018, 02:06 PM | #25 | |
| Not sure. I remedied by offsetting the horn a tooth. Quote:
I have two trims steering and throttle behind my wheel and then straigth which is what you see me adjust in front of wheel.. Again... radio steering trim set to center and powered on, turn car power on, servo should center up, and allow a even throw from a 90degree horn install. At least in all my other setups they do. That's not the case. So either servo is off a tooth or radio doesnt like this servo. Last edited by THX_138; 11-26-2018 at 10:18 PM. | |
09-09-2018, 02:36 PM | #26 |
RCC Addict Join Date: Jun 2017 Location: Canada
Why is there a trim setting on the steering channel if it ****s up the steering throw? I don't think an option that is available on 90% of the radios would be "bad" and affect your servo in a negative way... Unless most high end servos have 180 degrees of throw? My holmes hobbies shv500 doesn't seem to be affected by my radio trim setting Sent from my Pixel 2 XL using Tapatalk |
09-09-2018, 02:44 PM | #27 | |
because with the short steering arm (top steering link) even if the servo is all centered correctly, left and right at the wheel will not be equal, because of the arc the servo horn makes. | |
09-09-2018, 03:18 PM | #28 |
Then it's calibration of the remote or software in the servo. By calibration of the remote, I don't mean the placement of the trim setting. Since you didn't have this issue before, it might not be that, cause that would effect all servos. So it's the software, of the servo, not teeth. Teeth being off might not allow the servo horn to point straight down. But they won't effect the distance from home to right and home to left in this way. The way to correct the software problem would be to adjust your trim away from center to tell the servo where center is suposed to be. Moving the servo horn over a tooth will not make the servo center properly, your throw will still be Un even. If moving the servo horn makes everything correct, and the wheels still each turn the same degrees from center, but the servo horn itself is not moving equal distance from center, then hooray. Last edited by Voodoobrew; 09-09-2018 at 03:23 PM. |
09-09-2018, 03:55 PM | #29 |
I made a picture of what I am talking about See if you have a short steering arm, you need to adjust the trim so that Home is not at the center of the full servo range, unless you have a funky servo that already does this for you because it won't center properly. Last edited by Voodoobrew; 09-09-2018 at 03:58 PM. |
09-09-2018, 04:02 PM | #30 | |
Sent from my SM-G965U using Tapatalk | |
09-09-2018, 04:14 PM | #31 | |
The Holmes Hobby servo can actually go 125% left and 125% right, roughly. So its possible when you adjust trim in your radio that it might be handled in a "smart" way that uses that extra 25% in each direction the keep the throw the same on each side. If you adjust the throw in the radio to go left 125% and right 125% so you can choke up on the servo horn and get more torque from the servo with out loosing steering throw, adjusting the trim will not be able to use the extra 25% to correct itself. | |
09-09-2018, 04:19 PM | #32 |
| Re: Reefs triple 5 not centering... It's $120 servo, the servo cant center properly send it back or ask for a replacement. I wouldn't settle for a servo that did this for that price.
09-09-2018, 04:24 PM | #33 |
But it’s a REEFS !!!! Can’t be a bad servo, I read Farcebeek and know this is the bestest servo ever made and the owner is an incredible dude!!! Hang up and Drive |
09-09-2018, 04:24 PM | #34 |
I'll be speaking with the owner of the comp tomorrow they got great customer service. Yes I will agree with an above statement not as fast as my savox... but 550oz of torque is sweet. Sent from my SM-G965U using Tapatalk |
09-09-2018, 05:04 PM | #35 |
Savox 2290 $120.00 If you follow directions. Erik is the best. https://dluxfab.ecwid.com/#!/Savox-s...egory=13250680 Hang up and Drive |
Reefs triple 5 not centering... - Similar Threads | ||||
tripple.111 2010 tc truck | tripple.111 | 2.2 Scale Rigs | 9 | 04-14-2011 06:46 PM |
BDW Tripple S ...yes another one! | kineteks | Axial AX-10 Scorpion | 25 | 10-01-2009 09:33 PM |
