09-08-2018, 06:36 PM | #1 |
Rock Stacker Join Date: Aug 2018 Location: Orlando
| Reefs triple 5 not centering...
Just bought a reefs triple 5 to replace my savox, and it refuses to center up no matter what I do.... any thoughts other than i have to go buy a radio that supports endpoint adjustment??? Everyone talked me into dropping savox for these and I will say super quiet and strong but this is driving me nuts. Sent from my SM-G965U using Tapatalk Last edited by "MIS-TAKEN"; 09-08-2018 at 06:42 PM. |
09-08-2018, 06:38 PM | #2 | |
I wanna be Dave Join Date: Dec 2006 Location: here
| Re: Reefs tripple 5 not centering...
Retun it... and buy hitec or another savox servo. That servo looks like a holmes hobbies knockoff. Quote:
09-08-2018, 06:40 PM | #3 | |
| Re: Reefs tripple 5 not centering... Quote:
Sent from my SM-G965U using Tapatalk | |
09-08-2018, 06:45 PM | #4 |
| Re: Reefs triple 5 not centering...
Maybe a better radio is your answer.. but imo it should center if your savox centered probably something wrong with the reef servo Sent from my SM-J727VPP using Tapatalk |
09-08-2018, 06:53 PM | #5 |
Dlux has some more of the Savox 1290’s at $120. Hands down the toughest you will ever meet in a standard sized servo. Use the code as shown https://dluxfab.ecwid.com/#!/Savox-s...egory=13250680 Hang up and Drive |
09-08-2018, 07:44 PM | #6 |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
I've heard good things about reefs servos, what radio are you using? I would contact reefs about this. Sent from my SM-G960W using Tapatalk |
09-08-2018, 07:47 PM | #7 | |
| Re: Reefs triple 5 not centering... Quote:
I got it to work out my horns just crooked put i got equal distance turning both ways at least. Sent from my SM-G965U using Tapatalk | |
09-08-2018, 08:03 PM | #8 |
You could try playing around with the length of the steering linkage to get it centered, though really a radio that can at least trim the steering would be handy. Oh and I think your wording is confusing people, Your Reefs servo works fine you just dont have a way of trimming it to get it centered, correct? Last edited by HumboldtEF; 09-08-2018 at 08:06 PM. |
09-08-2018, 08:09 PM | #9 | |
Had to rotate horn a tooth to get proper left right equal turning. All my savox kept the horn pointed str8 down and equal turning in both direction. Almost like this one is off a tooth internally. Sent from my SM-G965U using Tapatalk | |
09-08-2018, 08:13 PM | #10 |
what have you done to center the servo so far? When installing a servo you should set the radio end points to zero then turn the car on, so that the servo centers correctly, then attach the servo horn so that the wheels are straight. If you attach the servo horn first, with out finding center... well that's a good way to burn up and break stuff. If you feel its a teeth are half a tooth off that should be easily remedied by throttle trim to get the servo horn pointed straight down. As HumboldtEF said changing the length of the servo to spindle linkage by going in and out half a turn so that center is actualy center is a good way to adjust, so your new horn position centered would not be vertical as before. You could also try changing the link to a different hole in the servo horn. I prefer to the set the servo trim to 150% (not all radios support this) then use shortest servo horn I can manage and still get full steering travel at the wheels. It's like lowering the gear ration and gives you more steering torque in the end. If you really need the servo horn to be vertical, you could take the top of the servo off and rotate the inside gears a tooth then put it back together, could take a few tries, the get it where you like it. but since all the gears have a different number of teeth you can change that. I woulden't tho too much work. Last edited by Voodoobrew; 09-08-2018 at 08:32 PM. |
09-08-2018, 08:16 PM | #11 |
The way I was taught 30 years ago. Turn radio on set trim to zero turn car on let servo find center.... build steering linkage from there..... Sent from my SM-G965U using Tapatalk |
09-08-2018, 08:32 PM | #12 |
Rock Crawler Join Date: May 2018 Location: USA
Not the first person Ive heard to have an issue with reef bros. If you were gonna drop that kinda cash, should just get a 2290sg. more torque, less voltage requirement.
09-08-2018, 08:39 PM | #13 |
I think I've had maybe 2 servos & horns line up in a perfect direction ever. Too many variables between both. I have a 555, it is anything but fast. You want the bad ass on the block get a 2290. |
09-08-2018, 08:44 PM | #14 |
That works for now. Sent from my SM-G965U using Tapatalk |
09-08-2018, 09:33 PM | #15 |
RCC Addict Join Date: Jun 2017 Location: Canada
For that kind of cash, Holmes shv500v2... Sent from my Pixel 2 XL using Tapatalk |
09-09-2018, 04:25 AM | #16 |
If the issue is that its not straight up and down, because of the length of the upper steering arm, you can go to lowes or home depo and buy 3/16 steel rod and thread the ends at the length you want. Or possibly try the longer revo rod ends. Part# TRA5525 Traxxas Rod Ends w/Hollow Balls (12) |
09-09-2018, 07:33 AM | #17 | |
When you place the horn on the servo it should be a perfect 0, 90, 180, 270, 360 position and have full swing in both directions. In order to get full swing I need to rotate one more tooth which tells me something inside isnt right, or I need a fancy radio which is just dumb, as my savox never gave me this issue with the most basic radios. It wont let me post the video. Sent from my SM-G965U using Tapatalk Last edited by "MIS-TAKEN"; 09-09-2018 at 07:59 AM. | |
09-09-2018, 10:34 AM | #18 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
I have had a lot of different servos by a lot of different manufacturers and it is rare that I have one line up perfectly straight with 0 trim. I dont think it is possible to have one line up perfectly at every 90 degrees...25 splines to line up.
09-09-2018, 11:00 AM | #19 |
Missing what's going on here guys. Put servo horn on at 90degree. It should swing say 45degrees one way 45 degrees the other Not 50 degrees one way 30 degrees the other... Sent from my SM-G965U using Tapatalk |
09-09-2018, 11:03 AM | #20 |
The trim from your radio will compensate for any misalignment no? Sent from my Pixel 2 XL using Tapatalk |
Reefs triple 5 not centering... - Similar Threads | ||||
tripple.111 2010 tc truck | tripple.111 | 2.2 Scale Rigs | 9 | 04-14-2011 06:46 PM |
BDW Tripple S ...yes another one! | kineteks | Axial AX-10 Scorpion | 25 | 10-01-2009 09:33 PM |
