1s drone battery to power led lights. Would a 1s drone battery be strong enough to power extra led lights on my rig? Thanks for any help. Sent from my SM-G930V using Tapatalk |
Re: 1s drone battery to power led lights. 3.7 volts is a bit low. What do your lights run on now, the receiver? If its the receiver they're likely getting 5-6 volts. Also whats the mah rating on the battery? If its tiny it might not last long. |
Re: 1s drone battery to power led lights. Quote:
Re: 1s drone battery to power led lights. |
Re: 1s drone battery to power led lights. It all depends on what voltage the LEDs are made to run on. A resistor swap could make them run on anywhere from 3-12V but it sounds like they are set up for 6V. They wouldn't be very bright (or might not light up at all) on a 1S battery. If you really want a battery just for lights, consider a small 2S Life pack like this: https://hobbyking.com/en_us/zippy-fl...iver-pack.html |
Re: 1s drone battery to power led lights. I know a 9v will work but how bright does it make your lights and how long does it last? Thanks btw. Sent from my SM-G930V using Tapatalk |
Re: 1s drone battery to power led lights. you don't necessarily just want the "smallest". You want to make sure that it'll run those lights for however long your plan to run your vehicle for. If your vehicle gets a couple hours of runtime, then make sure you get a big enough battery to provide a couple hours of run time for those lights. Hobbyking is probably going to provide the best selection for 3S batteries. |
