10-09-2018, 02:36 PM | #1 |
Quarry Creeper Join Date: Aug 2018 Location: calgary
| 25 minute run time battery
So i have 2 Common Sense R/C . CSR Lectron Pro 7.4V 5200MAH 35C LIPO PK XT60 W/TRX Adapter Run on 2 different TRX-4 and about 5-7 minutes on low speed and 17-20 minutes on high speed and low voltage kicks in about 25 minutes, on 2 stock trx. Doesn't seem right to me? |
10-09-2018, 02:46 PM | #2 |
RCC Addict Join Date: Feb 2016 Location: Princeton, North Carolina, USA
| Re: 25 minute run time battery
No, not even close. Did you temp the battery right after running? Didn't you say a while back you got an hour run time from those packs? Last edited by 2mtech; 10-09-2018 at 02:49 PM. |
10-09-2018, 02:55 PM | #3 |
How many mah actually went back into them when you charged them?
10-09-2018, 06:24 PM | #4 |
Have you checked the cell voltages?
10-09-2018, 08:05 PM | #5 | |
| Re: 25 minute run time battery Quote:
I did get an hour when i was strickly on low speed and just a litte bit of high gear. | |
10-09-2018, 08:07 PM | #6 |
Rock Stacker Join Date: Jan 2018 Location: Ivins, the Red Rock Southwest
what kind of charger you got ? do you have a balance charge provision or are you relying on the balance plug ? if you ave the ability do a storage discharge at low amp (.5 maybe ) then do a very slow balance charge .
10-09-2018, 08:07 PM | #7 |
Who knows about how much charge, its being charge buy a crappy traxxas charger. I have not checked the cells yet buy My brand new charger , hobbywing 1080 and savox servo , just showed up. So we see how my new charger goes. |
10-09-2018, 08:08 PM | #8 |
| Re: 25 minute run time battery Me thinks you're going to see your problem go away with that SkyRC charger.
10-09-2018, 08:14 PM | #9 |
| Re: 25 minute run time battery |
10-09-2018, 08:17 PM | #10 |
10-09-2018, 09:14 PM | #11 |
5000mah lasts me about 6 hours. But I stand around and talk a lot. I also spend 90% of the time under 20% throttle. In the snow if you're at full throttle all the time, half hour might not be so bad. Also your esc has settings for low voltage that can tell the car to shut off sooner. The cold will also lower the batteries chemical reactions reducing the voltage. Also check that the esc thinks the battery is 2s and not 3s. Usualy denoted by a series of beeps when you plug it in. And +1 for the sky rc charger. I love my imax b6 mini |
25 minute run time battery - Similar Threads | ||||
Run Time vs Battery mha and Bed Battery | Greatscott | RC4WD Trail Finder 2 | 4 | 09-18-2017 09:25 PM |
Run time on battery XR-10 vs AX-10 | MikeSSS | General Crawlers | 0 | 09-03-2010 08:45 AM |
battery run time losi battery | perez62682 | Team Losi Comp Crawler | 4 | 03-14-2010 08:22 PM |
battery run time | piper92 | Electronics | 2 | 10-28-2008 12:57 AM |
Battery Run Time | JasonA | General Crawlers | 2 | 11-14-2006 10:29 AM |
