10-21-2018, 08:20 AM | #1 |
RCC Addict Join Date: Sep 2010 Location: Apollo Pa
| Traxxas TRX4 Bronco light kit
I've changed out my stock Traxxas ESC to a Hobbywing 1080 and thinking about getting the Traxxas light kit for my Bronco, Does anyone know the voltage needs for the Traxxas system?
10-21-2018, 08:49 AM | #2 |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: Traxxas TRX4 Bronco light kit
The Traxxas Lightcontroller is just a DC/DC converter which puts 3V 500mA out. So you need 3V if you use the org. Traxxas Lights. To get the 3V you can use a adj DC/DC converter from ebay which are really cheap (got 4 for 3$) there are several ones, that what i did and they can put out up to 3A |
10-21-2018, 09:13 AM | #3 |
[QUOTE=magic_yeti;5877766]The Traxxas Lightcontroller is just a DC/DC converter which puts 3V 500mA out. So you need 3V if you use the org. Traxxas Lights. To get the 3V you can use a adj DC/DC converter from ebay which are really cheap (got 4 for 3$) there are several ones, that what i did and they can put out up to 3A Interesting do you have a link? Have a pic or a diagram how you wired it up? One other question do you think a one cell lipo at 4.2 volts would be too much voltage? |
10-21-2018, 11:04 AM | #4 |
just search for Mini 3A DC-DC Konverter Step Down Buck on ebay wiring is easy solder on the 2 input and the 2 output cables then use a voltmeter to adj. the output Voltage over the little screw Afterwards i used seal spray (liquid pvc) to waterproof it 4.2v could be too much, theres no information about the tolerance of the traxxas stuff Last edited by magic_yeti; 10-21-2018 at 11:07 AM. |
10-21-2018, 11:41 AM | #5 |
Ok thank you for the info!
Traxxas TRX4 Bronco light kit - Similar Threads | ||||
Trx4 bronco with Sport body and traxxas lift kit | Exiwolfman | Traxxas TRX-4 | 0 | 10-13-2018 02:20 PM |
Traxxas Bronco light kit | HTFU Defender | Traxxas TRX-4 | 0 | 06-25-2018 09:06 AM |
Traxxas Official TRX-4 Bronco Light Kit | ScoJac | Traxxas TRX-4 | 9 | 06-11-2018 10:09 AM |
