11-08-2018, 02:49 PM | #1 |
Rock Stacker Join Date: Jan 2018 Location: Ivins, the Red Rock Southwest
| Timing of motor vs ESC timing
what is the relationship between the “as built” motor timing ( re: Holmes Trailmaster 540 zero timing ) and the timing selection on Hobbywing ESC of 16 degrees. how is one affected by the other ? Is motor performance enhanced or degraded by the ESC timing choice ? |
11-08-2018, 07:23 PM | #2 |
| Re: Timing of motor vs ESC timing
I think one is for brushed the other is for brushless. Brushed motors get timing from twisting the can. Brushless motors get timing from the esc. The esc can also cheat and adjust the timing on the fly so you have more power through the rpm range. On the motor Timing is fixed. |
11-08-2018, 10:07 PM | #3 |
Rock Crawler Join Date: Feb 2012 Location: Michigan
Voodoo almost has it, but the brushless also has can timing also. Just like a brushed motor has.
11-09-2018, 09:55 AM | #4 |
Rock Crawler Join Date: May 2016 Location: SoWIs
Only sensored brushless. Brushless windings & magnets are fixed so only motors with movable sensor boards can have can timing. Can timing and ESC timing on a sensored motor work the same. Sensorless timing is just the ESC predicting rotor position based on EMI feedback, and probably why some [cheaper] ESC's cog a lot more. |
11-10-2018, 01:37 PM | #5 |
Pebble Pounder Join Date: Oct 2018 Location: northen ohio
brushed motor timing is important, and can make or break in racing. (not so much anymore) but brushless seems very strange. i never understood why a 3phase motor would have such adjustment. its all based off the esc (VFD/VVD) OUTPUT. Even still, most brushless motors i have (sensored) only go down to 15deg, which again, whats the point? why not go to 0. The ESC knows INSTANTLY where the rotor is it just has no clue how much power is actualy needed for movement. one the same topic, anyone ever use or see a 6 or 8 pole 540motor (or 550) ? wouldnt 6 or 8 pole be the ideal choice for very slow rpm and control? (more poles = larger feedback (INDUCTIVE REACTANCE CHANGE) for esc to read) Sent from my SM-N910V using Tapatalk |
11-10-2018, 02:43 PM | #6 |
Quarry Creeper Join Date: Apr 2010 Location: Baraboo
Generically speaking, More timing = more RPM = more amperage draw (read heat) Less Timing = more Torque Brushed = Motor timing only. Brushless/Sensorless = ESC timing only. Brushless/Sensored = ESC &/or Motor timing. |
Timing of motor vs ESC timing - Similar Threads | ||||
motor timing | cowboy_crawler | Electronics | 6 | 12-10-2012 07:43 AM |
MMP timing problems. How do I offset mechanical timing? | Olle P | Electronics | 44 | 12-08-2012 03:59 AM |
Motor timing.... | brokennib | Electronics | 5 | 01-19-2011 04:58 PM |
Timing a Motor | Harvo | Newbie General | 7 | 12-23-2008 07:00 PM |
Motor Timing | Rooney7783 | Electronics | 9 | 03-08-2006 03:07 PM |
