11-21-2018, 06:01 PM | #1 |
Rock Stacker Join Date: Aug 2018 Location: Scotland
| Rc4wd wireless winch on 3s (battery shows 12.5v charged)
Hi guys, I have just fitted my new rc4wd parts and although I've tried the winch on 3s quickly and it works I'm scared to use it too much of its going to burn out quickly. I've seen many old posts saying yay or nay for 3s with no bec but the documentation say's 3s is ok but not over 11.1V! It's going to be over 11.1 on a fully charged battery a lot! Any advice? Thoughts? Also are the rc4wd winch parts ok with a small amount of water, looks like a no going by docs. Cheers |
11-21-2018, 06:50 PM | #2 |
Rock Stacker Join Date: Aug 2012 Location: Jacksonville, FL
| Re: Rc4wd wireless winch on 3s (battery shows 12.5v charged)
Its powered off of the receiver through the esc though right. If so it should be at whatever the esc is outputting, which will be less than the 12+ of a fully charged battery. Sent from my SAMSUNG-SM-G891A using Tapatalk |
11-21-2018, 06:51 PM | #3 |
And I would avoid water unless you take it apart and waterproof it yourself. Sent from my SAMSUNG-SM-G891A using Tapatalk |
11-21-2018, 11:26 PM | #4 |
| Re: Rc4wd wireless winch on 3s (battery shows 12.5v charged) No, it's powered as others have suggested in previous posts to people on here, right of the battery with a soldered connector. The only ESC output I have would be the one going to the receiver at say 6v so I'd have to tap the receiver power and I don't have a free slot left. Apparently it works better at the higher voltage. :S
11-22-2018, 04:52 AM | #5 |
Copied this from RC4WD.com, "Some Lipo battery voltage can be higher than 11.1 volts. Please be careful and check voltage before using your battery. Use a BEC if needing to use a 3 cell lipo.*" So looks like adding a BEC is going be your best best. Or buying a smaller battery just for the winch. Sent from my SAMSUNG-SM-G891A using Tapatalk |
11-22-2018, 09:52 AM | #6 | |
| Re: Rc4wd wireless winch on 3s (battery shows 12.5v charged) Quote:
11-22-2018, 11:37 AM | #7 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
I run my RC4wd winch on direct 3s, but my winch controller is a servo board I modified. Signal goes to RX and power comes from 3s. It is fast but you need to be careful not to bump the switch or make sure you dont have any winch creep. It will burn out the motor.
11-22-2018, 12:29 PM | #8 | |
Thanks for the input | |
11-23-2018, 01:07 PM | #9 |
It seems funny that RC4WD would only rate the winch controller to 11.1vdc, eluding to the idea that is is 3S capable. If it can be ran off of 3S, then it should say that. The nominal voltage of a single lipo cell is 3.7vdc (3S = 11.1vdc). But, the normal charged voltage of a lipo cell is 4.2 - 4.3vdc (3S = 12.6 - 12.9VDC). If they are going to specify an operating voltage it should be 13vdc. With this, I do not use RC4WD controllers, they are ok, but they are a pain to waterproof, and for the money, are very basic. I run my winches off of 1/18 scale waterproof ESCs. They operate a lot quicker, and give linear control over pay out and pay in. Plus, they are less expensive than the RC4WD controllers Sent from my iPhone using Tapatalk |
11-23-2018, 01:14 PM | #10 |
I just buy the heyok wireless winch controller and keep the fob on my radio... no issues with winch creep or anything else..easy as pie and works great!
11-24-2018, 07:55 AM | #11 | |
11-24-2018, 09:09 AM | #12 | |
Newbie Join Date: Jan 2018 Location: British Columbia
11-24-2018, 09:59 AM | #13 | |
11-24-2018, 10:04 AM | #14 |
| Re: Rc4wd wireless winch on 3s (battery shows 12.5v charged) |
Rc4wd wireless winch on 3s (battery shows 12.5v charged) - Similar Threads | ||||
RC4wd wireless winch | meanbgreen | General Crawlers | 36 | 04-11-2012 05:27 PM |
rc4wd wirelEss winch | mtmayhem | Scale Accessories | 12 | 08-20-2011 07:30 PM |
