03-18-2019, 08:52 PM | #161 |
Rock Crawler Join Date: Jul 2016 Location: Southern Oregon
| Re: Spektrum DX5 Rugged
Picked one up myself a little over a week ago. Waited until I had a chance to go to Amain so I could actually put hands on it before buying it. Overall build quality feels pretty decent to me. Pretty solid and has just a little bit of heft to it. As others have said, scroll pad takes a minute to get used to, wish you could set it up for taps instead of sliding, but it's certainly usable. Also agree thumb lever is a little short, should be fixable though. Pretty happy with it overall. Sent from my SM-G930V using Tapatalk |
03-19-2019, 06:13 AM | #162 | |
| Re: Spektrum DX5 Rugged Quote:
Spektrum DX5 Rugged I used a Hobbyking 2S 2100 mah life pack that fits the Futaba 4PX/4PV. | |
03-20-2019, 04:43 PM | #163 |
RCC Addict Join Date: May 2007 Location: pasadena, tx
are the channels able to be assigned a type like linear or 3pos.?
03-24-2019, 09:56 PM | #164 |
Rock Crawler Join Date: May 2012 Location: Central PA
| Re: Spektrum DX5 Rugged Yes you can. I have my Aux 1 channel setup for my winch on 3 pos. and my Aux 2 channel I have my Castle Micro X Aux plug setup linear for adjustable drag brakes. You can also assign which switch you use. I'm using C for my winch and D for my adjustable drag brakes.
03-24-2019, 10:16 PM | #165 |
I had my first time out with my new Spektrum Rugged today. When I first got it I really didn't like the way SPektrum has the touch style buttons but now that I sat and messing around with it I find it's much easier to use but it's still not my favorite setup button wise vs other brand radios I have used. Ok that being said it's really the only complaint I have. The screens and ease of use I fnd to be very easy and espically I have not used Spektrum stuff since the original radios Spektrum had out which I didn't care for overall quality wise and the receivers losing bind on hard hits. Got what I didn't like out. Lets get into what I do like. Only been crawling for about 6 months so never had the need for a winch. The Rugged was very easy to program my Aux swith assign function and setup so that I can use the winch off the assigned switch (c) that I used. Very cool feature. Next I used the Aux assign again and setup Aux channel 2 to (D) which I setup to have adjustable drag brakes on my Castle Micro X esc. Really like that it's pretty easy to do. THe new SR515 receiver is a nice small size and being 5 channel is a nice touch. The SR515 receiver is a nice compact size and works great in my crawler. The added lever so you can throttle and drive with the same hand is a nice touch. Overall other than the touch buttons to adjust the main screens that I don't care for I really like the rest of the radio and after using it for 5 hours crawling I have to say it is an excellent radio overall. |
03-27-2019, 07:53 AM | #166 |
| Re: Spektrum DX5 Rugged thanks!
03-29-2019, 06:17 AM | #167 |
Newbie Join Date: Nov 2017 Location: Virginia Bch
I have a question. I was setting up my rugged last night. I'm using A as aux1 for the my winch have it set up as momentary and when I hit the button I'm getting winch and throttle together. How do I change it so it just operates the winch?
03-29-2019, 09:56 AM | #168 | |
Sent from my SM-G930V using Tapatalk | |
03-29-2019, 10:22 AM | #169 |
| Re: Spektrum DX5 Rugged |
04-01-2019, 10:28 AM | #170 |
Newbie Join Date: Mar 2015 Location: g-town
I am used to Knob type adjustments... How do you adjust the steering trim on the fly, or turn my idle up or down on my nitros???
04-01-2019, 12:43 PM | #171 |
Use liner mode on the switch of your choice.
04-07-2019, 03:35 PM | #172 | |
04-09-2019, 05:43 PM | #173 |
Newbie Join Date: Apr 2019 Location: Greece/Athens
I have several problems with the dx5. from the first hour broke the rubber strap hoop. another serious thing that makes and I do not understand why,it's that the channels are out of order and sometimes I go into the aux settings and there are no adjustments! other times if push the throttle trim I cannot adjust it to 0% and the car is going at the same time! so far disappointed
04-10-2019, 12:07 PM | #174 |
Reduce the steps on your trim to 4 or 5 in the trim setup menu. I had the same issue as 9 was to big a step. As for aux being out of order I have no Idea, but may have been how things were programmed. Try setting up a new model. |
04-10-2019, 05:40 PM | #175 |
Pebble Pounder Join Date: Feb 2019 Location: SIGNAL MOUNTAIN
Random question. Does this, or the DX5c, have a decently strong trigger spring? I currently have a DX2e and the throttle trigger is WAY too light with barely any resistance.
04-10-2019, 10:56 PM | #176 |
04-11-2019, 07:42 AM | #177 |
Quarry Creeper Join Date: Nov 2010 Location: land of no rocks
| Spektrum DX5 Rugged
So does anyone know if you can still use the older ar6000 recivers? Sent from my iPhone X using Tapatalk |
04-11-2019, 08:17 AM | #178 |
04-11-2019, 12:12 PM | #179 |
can anyone explain to me how put drag brakes in a channel? It is possible with hobbywing 1080?
04-11-2019, 12:21 PM | #180 |
Newbie Join Date: Jul 2018 Location: Bucharest, RO
You put drag brake in the ESC, not in the TX. Sent from my SM-N960F using Tapatalk |
Tags |
dx5, radio, rugged, spektrum, transmitter |
Spektrum DX5 Rugged - Similar Threads | ||||
NEW Spektrum DX5 Pro In Stock!! | RPP Hobby | RPP Hobby | 2 | 07-30-2018 09:12 AM |
dx5 or dx6? | rockin86runner | Electronics | 7 | 11-30-2011 11:06 AM |
Spektrum DX5 | Kanine38 | Electronics | 1 | 09-07-2010 05:12 AM |
dx5 or dx6? | dirtman | Electronics | 10 | 03-12-2009 11:40 AM |
new spektrum dx5, with traxxas xl-5 esc, motor? | drnedatsnov | Electronics | 2 | 01-31-2009 03:48 PM |
