12-11-2018, 09:31 PM | #1 |
RCC Addict Join Date: Feb 2017 Location: Surprise
| M17
Has anyone seen this ? http://www.rcracingpro.com/index.php...product_id=835 I know its mostly for racing, but hey, why not ? Sent from my LGMP450 using Tapatalk |
12-11-2018, 09:56 PM | #2 |
| Re: M17
Good lord, that radio is only $530 from amain. If I was going to upgrade from my mt4 it would be to an m12s since it has a thumb lever. https://www.amainhobbies.com/sanwa-a...caAnWpEALw_wcB |
12-11-2018, 10:35 PM | #3 | |
Quarry Creeper Join Date: Nov 2006 Location: Lexington Park
| Re: M17 Quote:
Sent from my SM-G965U using Tapatalk | |
12-11-2018, 10:50 PM | #4 |
| Re: M17 I use it to control the mix between front and rear axles on my berg (MOA) but it can be used for rear steer or winch control very easily.
12-12-2018, 06:10 AM | #5 |
| Re: M17 I use the lever for a winch on a few trucks and it is the best method for controlling one. If you use a ESC as a winch controller, you get actual proportional speed control unlike buttons or switches.
12-12-2018, 06:50 AM | #6 | |
| Re: M17 Quote:
I liked my MT4, it was a solid radio. The receivers are very expensive and it is confusing as to which receivers will work with which radio. As far as the radio above, it looks schweet, but it is likely a bit overkill for what we do in the crawling/scale world. Plus, $500+ and only four channels? | |
12-12-2018, 07:08 AM | #7 | |
| Re: M17 Quote:
This radio isn't one you'd want to take out in the woods and drop on the trail. | |
12-12-2018, 07:46 AM | #8 | |
| Re: M17 Quote:
If you drop it that's on you since it has a lanyard loop. | |
12-12-2018, 07:58 AM | #9 |
| Re: M17 |
12-12-2018, 08:10 AM | #10 |
| Re: M17
My lanyards are black thanks. I wouldn't mind if the detent was a bit crisper than it is though. As it is if it isn't on zero sometimes an esc won't arm. |
12-12-2018, 09:52 AM | #11 |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
| Re: M17
Is the detent spring loaded? Sent from my SM-G960W using Tapatalk |
12-12-2018, 10:04 AM | #12 |
| Re: M17
I believe the detent is built into the potentiometer.
12-12-2018, 12:42 PM | #13 |
| Re: M17 |
M17 - Similar Threads | ||||
Pre-Order Now the NEW Sanwa M17 FH5 w/ RX-491 Receiver! | RPP Hobby | RPP Hobby | 0 | 08-03-2018 03:20 PM |
